TUSB501-Q1是第3 代3.3V USB 3.0单通道转接驱动器。当5Gbps超高速USB信号在印刷电路板(PCB)或电缆上传输时,其完整性会在通道损耗和码间串扰的影响下有所降低.TUSB501-Q1可通过应用均衡功能来补偿通道损耗,从而恢复传入的数据,并使用较高的差分电压驱动信号。这样可扩展通道长度,并且使系统能够通过USB3.0标准.TUSB501-Q1的高级状态机方便主机和设备有效查看其状态。
上电后,TUSB501-Q1会定期在TX对上执行接收器检测。如果检测到SuperSpeed USB接收器,则使能RX端,TUSB501-Q1准备转接驱动。
接收器均衡器具有三个由引脚EQ控制的增益设置:3dB,6dB和9dB。该增益应根据TUSB501-Q1之前的损耗量进行设置。相似地,输出驱动器支持去加重和输出摆动配置(引脚DE和OS)。借助这些设置,可以将TUSB501-Q1灵活置于SuperSpeed USB路径上,同时保持优异性能。
与之前几代产品相比,TUSB501-Q1特有更低的功耗(所有链路状态下),更强的OS选项,改进的接收器均衡设置以及智能LFPS控制器。该控制器可感测低频信号并自动禁用驱动器去加重功能,完全符合USB 3.0标准。
TUSB501-Q1采用小型2mm x 2mm QFN封装,可在-40°C至105°C的工业级温度范围内运行。
所有商标均为其各自所有者的财产。
| Device Type |
| Number of Channels (#) |
| Configuration |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Ron (Typ) (Ohms) |
| Input/Ouput Voltage (Min) (V) |
| Input/Ouput Voltage (Max) (V) |
| ICC (Max) (uA) |
| Bandwidth (MHz) |
| ESD HBM (Typ) (kV) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| TUSB501-Q1 | TUSB1002 | TUSB1002A | TUSB501 | TUSB522P | TUSB551 |
| Redriver | Redriver | Redriver | Redriver | Redriver | Redriver |
| 1 | 2 | 2 | 1 | 2 | 1 |
| Single-channel | Dual-channel, Dual-lane | Dual-channel, Dual-lane | Single-channel | Dual-channel, Sigle-lane | Single-channel |
| 3 | 3 | 3 | 3 | 3 | 1.62 |
| 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 1.98 |
| NA | NA | NA | NA | NA | |
| 0.1 | 0 | -0.5 | 0.1 | 0.1 | 0 |
| 1.2 | 1.7 | 4 | 1.2 | 1.2 | 1.2 |
| 65mA | 103mA | 100mA | 65mA | 98mA | 82mA |
| 2500 | 5000 | 5000 | 2500 | 2500 | 2500 |
| 5 | 6 | 5 | 5 | 4 | |
| Aggressive Low-Power Architecture | Ultra-low-power architecture | Ultra-low-power architecture | Aggressive Low-Power Architecture | Ultra low-power architecture | 1.8V power Supply |
| Automotive | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 105 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 | -40 to 85 0 to 70 | -40 to 85 |
| WSON | VQFN | VQFN | WSON | VQFN | X2QFN |
| See datasheet (WSON) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) | See datasheet (WSON) | 24VQFN: 16 mm2: 4 x 4(VQFN) | 12X2QFN: 3 mm2: 1.6 x 1.6(X2QFN) |
| 8WSON | 24VQFN | 24VQFN | 8WSON | 24VQFN | 12X2QFN |
