数据: TPS56x210A 采用 8 引脚 SOT-23 封装的4.5V 至 17V 输入、2A/3A 同步降压稳压器 数据表
TPS562210A和TPS563210A是采用8引脚SOT-23封装的简单易用型2A /3A同步降压转换器。
两款器件均经过优化,最大限度地减少了运行所需的外部组件并且可以实现低待机电流。
这些开关模式电源(SMPS)器件采用D-CAP2™模式控制,从而 该设备可在高级Eco-mode™下运行,从而能在轻载运行期间保持高效率.TPS562210A和TPS563210A采用8引脚1.6mm×2.9mm SOT(DDF)封装,额定环境温度范围为-40°C至85°C 。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS563210A | TPS562210A | TPS562219A | TPS563219A |
| 4.5 | 4.5 | 4.5 | 4.5 |
| 17 | 17 | 17 | 17 |
| 0.76 | 0.76 | 0.76 | 0.76 |
| 7 | 7 | 5.5 | 5.5 |
| 3 | 2 | 2 | 3 |
| 1 | 1 | 1 | 1 |
| 650 | 650 | 650 | 650 |
| 0.19 | 0.23 | 0.65 | 0.65 |
| Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification |
| D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 |
| 80 | 80 | 80 | 80 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog |
| SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN |
型号:TPS563210ADDFR 封装:SOT23-8
品牌:TI 描述:TPS563210A 采用 SOT-23 封装且具有高级 Eco-mode™、PG 和软启动功能的 17V 输入、3A 同步降压稳压器
金额:¥2.20500
去购买
