LM5141是一款同步降压转换器,适用于高电压宽输入电压的降压转换器。此控制方法基于峰值电流模式控制。电流模式控制可提供内部线路前馈,逐周期电流限制和简化的环路补偿.LM5141具有压摆率控制功能,能够轻松满足EMI要求。
LM5141有两种开关频率可选:2.2MHz和440kHz。栅极驱动器具有压摆率控制功能,可通过调整来降低EMI。
在轻负载或无负载条件下,LM5141通过在跳周期模式下运行来提升轻载效率.LM5141具备能够自动切换至外部偏置电源的高电压偏置稳压器,可以降低来自V IN 的I Q 电流。其他特性包括频率同步,逐周期电流限制,针对持续过载条件的断续模式故障保护以及电源正常输出。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| LM5141 | LM5116 | LM5117 |
| 3.8 | 6 | 5.5 |
| 65 | 100 | 65 |
| 1.5 | 1.215 | 0.8 |
| 15 | 80 | 62 |
| 20 | 20 | 20 |
| 1 | 1 | 1 |
| 1 | 1 | 1 |
| 350 | 50 | 50 |
| 2600 | 1000 | 750 |
| 0.035 | 4.6 | 4.8 |
| Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Spread Spectrum Synchronous Rectification UVLO Fixed | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable |
| 99 | 98 | 98 |
| -40 to 125 | -40 to 150 | -40 to 125 |
| Catalog | Catalog | Catalog |
| VQFN | HTSSOP | HTSSOP WQFN |
| Current Mode | Current Mode | Current Mode |
