LP8754旨在满足移动电话和类似便携式应用中最新应用处理器的电源管理需求。此器件包含6个降压DC-DC转换器内核,一起捆绑在6相位降压转换器中,。此器件由动态电压调节(DVS)接口或I 2 C兼容串行接口完全控制。
自动PWM /PFM操作搭配自动增相/切相功能,最大程度提高了宽泛输出电流范围内的效率.LP8754支持进行远程输分电压感测,以补偿稳压器输出与负载点之间的IR下降,从而提高输出电压的精度。
保护特性包括短路保护,电流限制,输入OVP,UVLO,温度警告以及关断功能。此器件还提供多个错误标志,用于指示集成电路(IC此外,I 2 C回读信息包括总负载电流以及各降压内核的负载电流:LP8754无需添加电流感测电阻就能感测到传递给负载的电流。在启动期间,器件会控制输出电压转换率,以最大程度降低过冲和浪涌电流。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LP8754 | LP8758-B0 | LP8758-E0 |
| 2.5 | 2.5 | 2.5 |
| 5 | 5.5 | 5.5 |
| 0.6 | 0.5 | 0.5 |
| 1.67 | 3.36 | 3.36 |
| 10 | 16 | 4 |
| 1 | 1 | 4 |
| 3000 | 3000 | 3000 |
| 4000 | 3000 | 3000 |
| 0.08 | 0.006 | 0.006 |
| Adjustable Current Limit Dynamic Voltage Scaling I2C Light Load Efficiency Multiple Outputs Phase Interleaving Power Good Remote Sense Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable Light Load Efficiency Multiple Outputs Output Discharge Phase Interleaving Power Good Remote Sense Synchronous Rectification | Adjustable Current Limit Dynamic Voltage Scaling Enable I2C Light Load Efficiency Multiple Outputs Output Discharge Phase Interleaving Power Good Remote Sense Synchronous Rectification |
| Current Mode | Current Mode | Current Mode |
| -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog |
| DSBGA | DSBGA | DSBGA |
