数据: TPS54361-Q1 4.5V 至 60V 输入,3.5A,降压直流-直流转换器 支持软启动和 Eco-mode™ 模式 数据表 (Rev. B)
TPS54361-Q1器件是一款60V,3.5A,降压稳压器,此稳压器具有一个集成的高侧金属氧化物半导体场效应晶体管(MOSFET)。按照ISO 7637标准,此器件能够耐受的抛负载脉冲高达65V。电流模式控制提供了简单的外部补偿和灵活的组件选择。低纹波脉冲跳跃模式和152μA的电源电流可以轻负载时实现高效率。当使能引脚被拉至低电平时,关断电源电流被减少至2μA。
欠压闭锁在内部设定为4.3V,但可用一个使能引脚上的外部电阻分压器将之提高。输出电压启动斜坡由软启动引脚控制,该引脚还可被配置用来控制定序/跟踪。一个开漏电源正常信号表示输出处于标称电压值的93%至106%之内。
宽可调开关频率范围可针对效率或者外部组件尺寸进行优化。逐周期电流值制,频率折返和热关断在过载条件下保护内部和外部组件。
TP S54361-Q1器件可提供10引脚
4 mm×4 mm WSON外露散热垫封装。
< small>所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54361-Q1 | TPS54060A | TPS54160A | TPS54361 | TPS54560 | TPS54561 |
| 4.5 | 3.5 | 3.5 | 4.5 | 4.5 | 4.5 |
| 60 | 60 | 60 | 60 | 60 | 60 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 59 | 58 | 58 | 59 | 58.8 | 59 |
| 3.5 | 0.5 | 1.5 | 3.5 | 5 | 5 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.152 | 0.116 | 0.116 | 0.152 | 0.146 | 0.152 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 98 | 98 | 98 | 98 | 98 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 |
| Automotive | Catalog | Catalog | Catalog | Catalog | Catalog |
| WSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | WSON | SO PowerPAD | WSON |
