TPS62160-Q1是一款易于使用的同步降压DC-DC转换器,针对高功率密度的应用进行了优化。该器件的开关频率典型值高达2.25MHz,允许使用小型电感器,通过利用DCS-Control拓扑技术提供快速的瞬态响应并实现高输出电压精度。
此器件具有3V至17V宽运行输入电压范围,非常适用于由锂离子或其它电池以及12V中间电源轨供电的系统。其输出电压为0.9V至6V,支持高达1A的持续输出电流(使用100%占空比模式)。
通过配置使能引脚和开漏电源正常状态引脚也可以实现电源排序。
在节能模式下,器件可根据输入电压(VIN)生成约17μA的静态电流。负载较小时可自动且无缝进入节能模式,同时该模式可保持整个负载范围内的高效率。在关断模式下,此器件会关闭且关断期间的流耗少于2μA。
此器件采用2mm× 2毫米(DSG)8引脚WSON封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62160-Q1 | TPS62162-Q1 | TPS62170-Q1 | TPS62171-Q1 | TPS62172-Q1 |
| 3 | 3 | 3 | 3 | 3 |
| 17 | 17 | 17 | 17 | 17 |
| 0.9 | 3.3 | 0.9 | 1.8 | 3.3 |
| 6 | 3.3 | 6 | 1.8 | 3.3 |
| 1 | 1 | 0.5 | 0.5 | 0.5 |
| 1 | 1 | 1 | 1 | 1 |
| 2250 | 2250 | 2250 | 2250 | 2250 |
| 0.017 | 0.017 | 0.017 | 0.017 | 0.017 |
| Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification |
| Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive |
| WSON | WSON | WSON | WSON | WSON |
型号:TPS62160DSGT 封装:WSON-8-EP(2x2)
品牌:TI 描述:是降压型-40℃~+85℃@(TA)1降压可调1A 0.9V~6V 3V~17V 2.25MHz WSON-8-EP(2x2)DC-DC转换器ROHS
金额:¥
去购买金额:¥6.63460
去购买金额:¥8.47500
去购买金额:¥
去购买
