LM25119Q器件是一款双路同步降压控制器,适用于高压电源或变化范围较大的输入电源的降压稳压器应用。此控制方法基于采用仿真电流斜坡的电流模式控制。电流模式控制可提供内部线路前馈,逐周期电流限制和简化的环路补偿。通过使用仿真电流斜坡可降低脉宽调制电路的噪声灵敏度,从而对高输入电压应用中所需的极小占空比进行可靠控制。开关频率可设定在50kHz至750kHz范围内.LM25119Q器件可驱动支持自适应死区时间控制的外部高侧和低侧N通道MOS功率开关。用户可选二极管仿真模式可实现断续模式运行,从而提高轻负载条件下的效率。凭借高压偏置稳压器以及自动切换至外部偏置的功能,可以进一步提高效率。特性包括:热关断,频率同步,逐周期和断续模式电流限制以及可调节线路欠压锁定。该器件采用功耗增强型32引脚无引线WQFN封装,并且配有利于散热的外露芯片连接焊盘。
<小>所有商标是其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| LM25119Q | LM25117-Q1 | LM5117-Q1 | LM5119Q | LM5140-Q1 | LM5141-Q1 | LM5642 |
| 4.5 | 4.5 | 5.5 | 5.5 | 3.8 | 3.8 | 4.5 |
| 42 | 42 | 65 | 65 | 65 | 65 | 36 |
| 0.8 | 0.8 | 0.8 | 0.8 | 1.5 | 1.5 | 1.236 |
| 41.3 | 41 | 62 | 64 | 15 | 15 | 34 |
| 40 | 20 | 20 | 15 | 40 | 20 | 20 |
| 2 | 1 | 1 | 2 | 2 | 1 | 2 |
| 2 | 1 | 1 | 2 | 1 | 1 | 2 |
| 50 | 50 | 50 | 50 | 350 | 350 | 150 |
| 750 | 750 | 750 | 750 | 2600 | 2600 | 250 |
| 6 | 4.8 | 4.8 | 6 | 0.035 | 0.035 | 1.1 |
| Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Phase Interleaving Power Good Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Synchronous Rectification |
| 98 | 98 | 98 | 98 | 78 | 78 | 99 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 150 | -40 to 150 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Catalog |
| WQFN | HTSSOP WQFN | HTSSOP WQFN | WQFN | VQFNP | VQFN | HTSSOP TSSOP |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | |
