数据: TPS40200 Wide Input Range Non-Synchronous Voltage Mode Controller 数据表
TPS40200是一款灵活的非同步控制器,内置200-mA驱动器,用于P沟道FET。该电路的输入电压最高可达52 V,具有省电功能,可在外部FET完全导通后关闭驱动器电流。此功能扩展了器件的灵活性,允许其在高达52 V的输入电压下工作,而不会消耗过多的功率。该电路采用电压模式反馈工作,具有前馈输入电压补偿,可立即响应输入电压变化。整体700 mV基准电压调整为2%,提供精确控制低电压的方法。 TPS40200采用8引脚SOIC和8引脚VSON封装,支持更复杂控制器的许多功能。时钟频率,软启动和过流限制均可通过单个外部组件轻松编程。该器件具有欠压锁定功能,可轻松与其他控制器或系统时钟同步,以满足排序和/或降噪要求。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| TPS40200 | LM25116 | LM25117 | LM25145 | LM3150 | TPS40200-EP | TPS40200-Q1 |
| 4.5 | 6 | 4.5 | 6 | 6 | 4.5 | 4.5 |
| 52 | 42 | 42 | 42 | 42 | 52 | 52 |
| 0.7 | 1.215 | 0.8 | 0.8 | 0.6 | 0.7 | 0.7 |
| 46 | 36 | 41 | 40 | 40 | 46 | 46 |
| 3 | 20 | 20 | 30 | 12 | 3 | 3 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 35 | 50 | 50 | 100 | 200 | 35 | 35 |
| 500 | 1000 | 750 | 1000 | 1000 | 500 | 500 |
| 1.5 | 4.6 | 4.8 | 1.8 | 3.5 | 1.5 | 1.5 |
| Frequency Synchronization | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable | Frequency Synchronization | Frequency Synchronization |
| 90 | 98 | 98 | 99 | 96 | 90 | 95 |
| -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -55 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | HiRel Enhanced Product | Automotive |
| SOIC SON | HTSSOP | HTSSOP WQFN | VQFN | HTSSOP | SOIC | SOIC |
| Voltage Mode | Current Mode | Current Mode | Voltage Mode | COT with emulated ripple | Voltage Mode | Voltage Mode |
