数据: 700-mW Mono Low-Voltage Audio Power Amplifier with Differential Inputs 数据表
TPA751是一款桥接负载(BTL)音频功率放大器,专为需要内置扬声器的低压应用而开发。 TPA751采用3.3V电源供电,可为BTL 8提供250mW的连续功率 -
在整个语音频段频率下,负载小于0.6%THD + N.虽然该器件的特性为20 kHz,但其操作已针对窄带应用(如无线通信)进行了优化。在大多数应用中,BTL配置无需在输出端使用外部耦合电容,这对于小型电池供电设备尤为重要。该器件具有关断功耗模式的关断模式,关断期间电源电流为1.5 nA。 TPA751采用3.0×3.0 mm MicroStar Junior? (BGA),8引脚SOIC表面贴装封装和表面贴装PowerPAD ?? MSOP。
PowerPAD和MicroStar Junior是德州仪器公司的商标。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TPA751 | TPA701 | TPA711 | TPA721 | TPA741 |
| Analog Input | Analog Input | Analog Input | Analog Input | Analog Input |
| Class-AB | Class-AB | Class-AB | Class-AB | Class-AB |
| Mono | Mono | Mono | Mono | Mono |
| 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 0.7 | 0.7 | 0.7 | 0.7 | 0.7 |
| 8 | 8 | 8 | 8 | 8 |
| 0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
| 1.45 | 1.25 | 1.25 | 1.25 | 1.45 |
| Hardware | Hardware | Hardware | Hardware | Hardware |
| Closed | Closed | Closed | Closed | Closed |
| 85 | 85 | 85 | 85 | 85 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
