INA181,INA2181和INA4181(INAx181)电流检测放大器专为经成本优化的应用而设计。这些器件是一系列双向电流检测放大器(也称为电流分流监控器),可在独立于电源电压的-0.2V至+ 26V范围内的共模电压中感测电流检测电阻器上的压降.INAx181系列集成有一个匹配的电阻器增益网络,具有四个固定增益器件选项:20V /V,50V /V,100V /V或200V /V.该匹配增益电阻器网络可最大限度地减小增益误差并降低温漂。
这些器件由2.7V至5.5V单电源供电。而双通道INA2181消耗的最大电源电流为500μA,四通道INA4181消耗的最大电源电流为900μA。
INA181采用6引脚SOT-23封装,INA2181采用10引脚VSSOP封装,INA4181采用20引脚TSSOP封装。所有器件选项的额定扩展工作温度范围均为-40°C至+ 125°C 。< /p>
所有商标均为其各自所有者的财产。
| Common Mode Voltage (Max) (V) |
| Common Mode Voltage (Min) (V) |
| Input Offset (+/-) (Max) (uV) |
| Input Offset Drift (+/-) (Typ) (uV/C) |
| Gain (V/V) |
| Gain Error (%) |
| Gain Error Drift (Max) (ppm/°C) |
| CMRR (Min) (dB) |
| Bandwidth (kHz) |
| Supply Voltage (Max) (V) |
| Supply Voltage (Min) (V) |
| Iq (Max) (mA) |
| Number of Channels (#) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| INA4181 | INA181 | INA2181 |
| 26 | 26 | 26 |
| -0.2 | -0.2 | -0.2 |
| 150 | 150 | 150 |
| 0.2 | 0.2 | 0.2 |
| 100 20 200 50 | 100 20 200 50 | 100 20 200 50 |
| 1 | 1 | 1 |
| 20 | 20 | 20 |
| 84 | 84 | 84 |
| 350 210 150 105 | 350 210 150 105 | 350 210 150 105 |
| 5.5 | 5.5 | 5.5 |
| 2.7 | 2.7 | 2.7 |
| 1 | 0.3 | 0.5 |
| 4 | 1 | 2 |
| Bi-directional Low-side Capable Quad channel | Bi-directional Low-side Capable | Bi-directional Dual channel Low-side Capable |
| Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 |
| TSSOP | SOT-23 | VSSOP |
| 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
