具有电压输出的INA270A-Q1和INA271A-Q1(INA27xA-Q1)系列电流分流监控器可以检测共模电流分流器的电压降电压范围为-16 V至+80 V,与电源电压无关。 INA27xA-Q1引脚可轻松实现滤波。
INA27xA-Q1器件具有两个输出电压范围:14 V /V和20 V /V.13 kHz带宽简化了电流控制的使用
INA27xA-Q1采用2.7 V至18 V单电源供电,最大电源电流为900μA。它们的额定温度范围为-40°C至+ 125°C,采用SOIC-8封装。
所有商标均为其各自的商标。拥有者。
| Common Mode Voltage (Max) (V) |
| Common Mode Voltage (Min) (V) |
| Input Offset (+/-) (Max) (uV) |
| Input Offset Drift (+/-) (Typ) (uV/C) |
| Gain (V/V) |
| Gain Error (%) |
| Gain Error Drift (Max) (ppm/°C) |
| CMRR (Min) (dB) |
| Bandwidth (kHz) |
| Supply Voltage (Max) (V) |
| Supply Voltage (Min) (V) |
| Iq (Max) (mA) |
| Number of Channels (#) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| INA270A-Q1 |
| 80 |
| -16 |
| 3000 |
| 2.5 |
| 14 20 |
| 2 |
| 50 |
| 100 |
| 130 |
| 18 |
| 2.7 |
| 0.95 |
| 1 |
| Low-side Capable |
| Automotive |
| -40 to 125 |
| SOIC |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
