THS4141 全差动输入/输出高转换率放大器
数据:
特性
  • 高性能
    • 160 MHz -3 dB带宽(V CC =±15 V)
    • 450 V /μs压摆率
    • -79 dB,1 MHz时的三次谐波失真
    • 6.5 nV / Hz 输入参考噪声
  • 差分输入/差分输出
    • 平衡输出抑制共模噪声
    • 由于差分输出导致的二次谐波失真减少
  • < li>宽电源范围
    • V CC = 5 V单电源至±15 V双电源
  • I CC(SD) =关断模式下的880μA(THS4140)
  • 主要应用
    • 单端至差分转换
    • 差分ADC驱动器< /li>
    • 差分抗锯齿
    • 差分发送器和接收器
    • 输出电平转换器
PowerPAD是德州仪器的商标。
参数 与其它产品相比 高速 运算放大器 (GBW>=50MHz)
Architecture
Number of Channels (#)
Total Supply Voltage (Min) (+5V=5, +/-5V=10)
Total Supply Voltage (Max) (+5V=5, +/-5V=10)
BW @ Acl (MHz)
Acl, min spec gain (V/V)
Slew Rate (Typ) (V/us)
Vn at Flatband (Typ) (nV/rtHz)
Vn at 1kHz (Typ) (nV/rtHz)
Iq per channel (Typ) (mA)
Vos (Offset Voltage @ 25C) (Max) (mV)
Rail-to-Rail
Features
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
CMRR (Typ) (dB)
Input Bias Current (Max) (pA)
Offset Drift (Typ) (uV/C)
GBW (Typ) (MHz)
Output Current (Typ) (mA)
2nd Harmonic (dBc)
3rd Harmonic (dBc)
@ MHz
THS4141 THS4130 THS4131 THS4140 THS4150 THS4151
Fully Differential
Voltage FB
Fully Differential
Voltage FB
Fully Differential
Voltage FB
Fully Differential
Voltage FB
Fully Differential
Voltage FB
Fully Differential
Voltage FB
1     1     1     1     1     1
4     4     4     4     4     4
33     33     33     33     33     33
160     150     150     160     150     150
1     1     1     1     1     1
450     52     52     450     650     650
6.5     1.3     1.3     6.5     7.6     7.6
6.7     1.5     1.5     6.7     8     8
13.2     12.3     12.3     13.2     17.5     17.5
7     2     2     7     7     7
No     No     No     No     No     No
N/A     Shutdown     N/A     Shutdown     Shutdown     N/A
Catalog     Catalog     Catalog     Catalog     Catalog     Catalog
-40 to 85
0 to 70
-40 to 85
0 to 70
-40 to 85
0 to 70
-40 to 85
0 to 70
-40 to 85
0 to 70
-40 to 85
0 to 70
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
MSOP-PowerPAD
SOIC
VSSOP
8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD)
8SOIC: 29 mm2: 6 x 4.9(SOIC)
8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
84     95     95     84     83     83
15000000     6000000     6000000     15000000     15000000     15000000
7     4.5     4.5     7     7     7
170     170     170     170     150     150
85     85     85     85     85     85
83     88     88     83     85     85
80     84     84     80     88     88
1     1     1     1     1     1
技术文档
数据手册(1)
元器件购买 THS4141 相关库存
