THS4041和THS4042是单/双,高速电压反馈放大器,能够驱动任何容性负载。这使它们成为各种应用的理想选择,包括驱动视频线或缓冲ADC。这些器件具有高165 MHz带宽和400 V /usec压摆率。对于反相和同相配置,THS4041 /2在所有增益下都是稳定的。对于视频应用,THS4041 /2具有出色的视频性能,差分增益误差为0.01%,差分相位误差为0.01°。这些放大器可将高达100 mA的电流驱动至20-
负载,并可在±5V范围内运行电源到±15V。
)| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4042 | THS4041 |
| Bipolar Voltage FB | Bipolar Voltage FB |
| 2 | 1 |
| 9 | 9 |
| 32 | 32 |
| 165 | 165 |
| 1 | 1 |
| 400 | 400 |
| 14 | 14 |
| 14 | 14 |
| 8 | 8 |
| 10 | 10 |
| No | No |
| High Cload Drive | High Cload Drive |
| Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 0 to 70 |
| MSOP-PowerPAD SOIC | MSOP-PowerPAD SOIC |
| 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
| 90 | 90 |
| 6000000 | 6000000 |
| 10 | 10 |
| 165 | 165 |
| 100 | 100 |
| 75 | 75 |
| 75 | 75 |
| 1 | 1 |
