数据: LMV82x Single/Dual/Quad, Low Voltage, Low Power, RRO, 5 MHz Operational Amplifiers 数据表
LMV821 /LMV822 /LMV824运算放大器为低电压,低功率系统带来了性能和经济性。采用5 MHz单位增益频率,2.7 V电源和1.4 V /μs压摆率,每个放大器的静态电流仅为220μA。它们提供轨到轨输出(RRO)摆幅为600Ω的负载。输入共模电压范围包括地,最大输入偏移电压为3.5 mV。它们还能够轻松驱动大容性负载,如应用部分所示。
LMV821单运放提供小巧的SC70-5封装,大约是之前产品持有量的一半, SOT23-5。 LMV824NDGV的工作温度范围为扩展工业温度范围,采用TVSOP封装。
总体而言,LMV821 /LMV822 /LMV824器件是低压,低功耗和高性能运算放大器,适用于各种应用。经济的价格。
所有商标均为各自所有者的财产。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| LMV821-N | LMV651 |
| 1 | 1 |
| 2.5 | 2.7 |
| 5.5 | 5.5 |
| 5.6 | 12 |
| 2 | 2.8 |
| In to V- Out | In to V- Out |
| 3.5 | 1.5 |
| 0.3 | 0.11 |
| 24 | 17 |
| Catalog | Catalog |
| -40 to 85 | -40 to 125 |
| SC70 SOT-23 | SC70 SOT-23 |
| 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 1 | 6.6 |
| Small Size | Small Size |
| 100000 | 100000 |
| 90 | 100 |
| 40 | 15 |
| Bipolar | Bipolar |
