LMC6034是一款CMOS四通道运算放大器,可以采用单电源供电,也可以采用双电源供电。其性能特点包括输入共模范围到达地,低输入偏置电流和高电压增益到实际负载,如2kΩ和600Ω。
该芯片采用美国国家半导体的先进双芯片 - 多晶硅栅极CMOS工艺。
有关具有这些相同功能的CMOS双运算放大器,请参阅LMC6032数据表。有关更高性能的特性,请参阅LMC660。
所有商标均为其各自所有者的财产。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| LMC6034 | LMC6032 |
| 4 | 2 |
| 4.75 | 4.75 |
| 15.5 | 15.5 |
| 1.4 | 1.4 |
| 1.1 | 1.1 |
| In to V- Out | In to V- Out |
| 9 | 9 |
| 0.38 | 0.38 |
| 22 | 22 |
| Catalog | Catalog |
| -40 to 85 | -40 to 85 |
| SOIC | PDIP SOIC |
| 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
| 2.3 | 2.3 |
| N/A | N/A |
| 0.4 | 0.4 |
| 83 | 83 |
| 40 | 40 |
| CMOS | CMOS |
