数据: TLV237x-Q1 550-µA/Channel, 3-MHz Rail-to-Rail Input and Output Operational Amplifiers 数据表
TLV237x-Q1器件是单电源运算放大器,提供轨到轨输入和输出功能。 TLV237x-Q1在扩展的汽车温度范围内将最低工作电源电压降至2.7 V,最高可达16 V.因此,宽电压范围既可以支持启停功能,也可以直接连接到典型的12 V电池。轨到轨功能允许器件最大化输出信号并避免削波。
CMOS输入可实现高阻抗,适用于发动机控制单元(ECU),车身控制模块(BCM),电池管理系统(BMS)和HEV /EV逆变器。这也允许用户绘制更低的偏移电压并保持低功耗,以帮助满足静态电流的整体系统需求,例如信息娱乐或集群,HEV /EV和动力系统。
此外,TLV237x -Q1系列支持高电源电压的共模电压轨。此功能不设置任何增益限制,可以支持任何级别的输入,而无需担心任何相位反转。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TLV2372-Q1 | TLV2370 | TLV2371 | TLV2371-EP | TLV2371-Q1 | TLV2372 | TLV2373 | TLV2374 | TLV2374-EP | TLV2374-Q1 | TLV2375 |
| 2 | 1 | 1 | 1 | 1 | 2 | 2 | 4 | 4 | 4 | 4 |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 | 16 |
| 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 |
| 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 | 2.4 |
| In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out |
| 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 |
| 39 | 39 | 39 | 39 | 39 | 39 | 39 | 39 | 39 | 39 | 39 |
| Automotive | Catalog | Catalog | HiRel Enhanced Product | Automotive | Catalog | Catalog | Catalog | HiRel Enhanced Product | Automotive | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -55 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -55 to 125 | -40 to 125 | -40 to 125 |
| SOIC | PDIP SOIC SOT-23 | PDIP SOIC SOT-23 | SOT-23 | SOIC SOT-23 | PDIP SOIC VSSOP | PDIP SOIC VSSOP | PDIP SOIC TSSOP | SOIC | SOIC TSSOP | PDIP SOIC TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| N/A | Shutdown | N/A | N/A | N/A | N/A | Shutdown | N/A | N/A | N/A | Shutdown |
| 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 | 60 |
| 72 | 72 | 72 | 72 | 72 | 72 | 72 | 72 | 72 | 72 | 72 |
| 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
