数据: Family of 1.8 V Hi-Speed Rail-to-Rail I/O Operational Amplifiers with Shutdown 数据表
TLV278x单电源运算放大器提供轨到轨输入和输出功能。 TLV278x在扩展的工业温度范围(?? 40°C至125°C)内将最低工作电源电压降至1.8 V,同时增加了轨到轨输出摆幅功能。 TLV278x还提供8 MHz带宽,仅需650μA电源电流。建议的最大电源电压为3.6 V,允许器件在两个可充电电池(±1.8 V电源低至±0.9 V)下工作。
宽带宽,低噪声和低噪声的组合失真使其成为高速和高分辨率数据转换器应用的理想选择。
所有成员均提供PDIP,SOIC和更新,更小的SOT-23(单通道),MSOP(双通道)和TSSOP(四边形)。
Hz \,10 kHz | Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TLV2780 | TLV2781 | TLV2782 | TLV2783 | TLV2784 | TLV2785 |
| 1 | 1 | 2 | 2 | 4 | 4 |
| 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 |
| 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 |
| 8 | 8 | 8 | 8 | 8 | 8 |
| 5 | 5 | 5 | 5 | 5 | 5 |
| In Out | In Out | In Out | In Out | In Out | In Out |
| 3 | 3 | 3 | 3 | 3 | 3 |
| 0.65 | 0.65 | 0.65 | 0.65 | 0.65 | 0.65 |
| 18 | 18 | 18 | 18 | 18 | 18 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 0 to 70 | -40 to 125 0 to 70 | -40 to 125 0 to 70 | -40 to 125 | 0 to 70 -40 to 125 | -40 to 125 0 to 70 |
| SOIC SOT-23 | SOIC SOT-23 | PDIP SOIC VSSOP | PDIP VSSOP | SOIC TSSOP | PDIP TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (PDIP) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| Shutdown | N/A | N/A | Shutdown | N/A | Shutdown |
| 15 | 15 | 15 | 15 | 15 | 15 |
| 80 | 80 | 80 | 80 | 80 | 80 |
| 17 | 17 | 17 | 17 | 17 | 17 |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
