数据: Family of Low-Power Rail-to-Rail Input/Output Operational Amplifiers w/Shutdown 数据表
TLV246x是一系列低功耗轨到轨输入/输出运算放大器,专为便携式应用而设计。输入共模电压范围超出电源轨,可在低压系统中实现最大动态范围。放大器输出具有轨到轨性能和高输出驱动能力,解决了旧式轨到轨输入/输出运算放大器的一个局限性。这种轨到轨动态范围和高输出驱动使TLV246x成为缓冲模数转换器的理想选择。
运算放大器具有6.4 MHz的带宽和1.6 V /μs的压摆率500μA电源电流,提供良好的交流性能和低功耗。器件提供可选的关断端子,可将放大器置于超低电源电流模式(I DD =0.3μA/ch)。在关断期间,运算放大器输出处于高阻态。直流应用的输入噪声电压为11 nV /
Hz,输入失调电压为100 μV。
Hz 符合JEDEC和行业标准的元件认证,确保在扩展温度范围内可靠运行。这包括但不限于高加速应力测试(HAST)或偏压85/85,温度循环,高压釜或无偏HAST,电迁移,键合金属间寿命和模塑化合物寿命。此类鉴定测试不应被视为超出规定的性能和环境限制使用该组件的合理性。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Output Current (Typ) (mA) |
| Offset Drift (Typ) (uV/C) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Architecture |
| IIB (Max) (pA) |
| CMRR (Typ) (dB) |
| Package Size: mm2:W x L (PKG) |
| TLV2462A-EP | TLV2460A | TLV2460A-Q1 | TLV2461A | TLV2462A | TLV2462A-Q1 | TLV2462AM | TLV2463A | TLV2463A-Q1 | TLV2464A | TLV2464A-EP | TLV2464A-Q1 |
| 2 | 1 | 1 | 1 | 2 | 2 | 2 | 2 | 2 | 4 | 4 | 4 |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
| 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 |
| 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 |
| In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out |
| 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 1.5 |
| 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 |
| HiRel Enhanced Product | Catalog | Automotive | Catalog | Catalog | Automotive | Military | Catalog | Automotive | Catalog | HiRel Enhanced Product | Automotive |
| -55 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -55 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -55 to 125 | -40 to 125 |
| SOIC | PDIP SOIC | TSSOP | PDIP SOIC | PDIP SOIC TSSOP | SOIC TSSOP | CDIP CFP LCCC | SOIC | TSSOP | PDIP SOIC TSSOP | SOIC TSSOP | TSSOP |
| 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 |
| Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar |
| 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 |
| 85 | 85 | 80 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (CDIP) See datasheet (CFP) 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 无样片 | 无样片 | 无样片 |
