LM94021是一款精密模拟输出CMOS集成电路温度传感器,工作电压低至1.5V。在-50°C至+ 150°C的宽温度范围内工作时,LM94021可提供与测量温度成反比的输出电压。 LM94021的低电源电流使其成为电池供电系统以及一般温度传感应用的理想选择。
两个逻辑输入,增益选择1(GS1)和增益选择0(GS0),选择增益温度 - 电压输出传递函数。可选择四个斜率:-5.5 mV /°C,-8.2 mV /°C,-10.9 mV /°C和-13.6 mV /°C。在最低增益配置中(GS1和GS0均为低电平),LM94021可以在1.5V电源下工作,同时测量整个-50°C至+ 150°C工作温度范围内的温度。将两个输入都拉高会导致传递函数具有-13.6 mV /°C的最大增益,以获得最大温度灵敏度。增益选择输入可以直接连接到V DD 或接地,无需任何上拉或下拉电阻,从而减少了元件数量和电路板面积。这些输入也可以由逻辑信号驱动,允许系统在操作或系统诊断期间优化增益。
| Local Sensor Accuracy (Max) (+/- C) |
| Operating Temperature Range (C) |
| Supply Voltage (Min) (V) |
| Supply Voltage (Max) (V) |
| Supply Current (Max) (uA) |
| Sensor Gain (mV/Deg C) |
| Rating |
| Features |
| Output Impedance (Ohm) |
| Interface |
| LM94021 | LM20 | LM94022 | LM94023 | LMT84 |
| 1.5 | 1.5 | 1.5 | 1.5 | 2.7 |
| -50 to 150 |
-40 to 125 -55 to 130 |
-50 to 150 | -50 to 150 | -50 to 150 |
| 1.5 | 2.4 | 1.5 | 1.5 | 1.5 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 12 | 7 | 8.1 | 8.1 | 8.1 |
| -5.5 to -13.6 | -11.7 | -5.5 to -13.6 | -5.5 or -8.2 | -5.5 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| UL Recognized |
Industry standard pinout UL Recognized |
Selectable gain setting UL Recognized |
Selectable gain setting | Industry standard pinout |
| 8 | 160 | 5.2 | 4.4 | |
| Analog Output | Analog Output | Analog Output | Analog Output | Analog Output |
