数据: SNx4LVC257A Quadruple 2-Line to 1-Line Data Selectors and Multiplexers With 3-State Outputs 数据表
这些四路2线至1线数据选择器和多路复用器设计用于1.65 V至3.6 VV CC <操作。
SNx4LVC257A器件设计用于将来自4位数据源的信号复用到总线组织系统中的4输出数据线。当输出使能(> OE )输入处于高逻辑电平时,3态输出不会加载数据线。
输入可以从3.3 V或5 V器件驱动。此功能允许在混合的3.3 V或5 V系统环境中将这些设备用作转换器。
| Function |
| Technology Family |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Channels (#) |
| Voltage (Nom) (V) |
| F @ Nom Voltage (Max) (Mhz) |
| ICC @ Nom Voltage (Max) (mA) |
| tpd @ Nom Voltage (Max) (ns) |
| Configuration |
| Type |
| IOL (Max) (mA) |
| IOH (Max) (mA) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Bits (#) |
| Digital input leakage (Max) (uA) |
| ESD Charged Device Model (kV) |
| ESD HBM (kV) |
| SN74LVC257A | SN54LVC257A | SN74LVC257A-EP | SN74LVC257A-Q1 |
| Encoder Multiplexer | Encoder/Multiplexer | Encoder/Multiplexer | Encoder |
| LVC | LVC | LVC | LVC |
| 1.65 | 2 | 2 | 2 |
| 3.6 | 3.6 | 3.6 | 3.6 |
| 4 | 4 | 4 | 4 |
| 1.8 2.5 2.7 3.3 | 2.7 3.3 | 2.7 3.3 | 2.7 3.3 |
| 100 | 100 | 100 | 100 |
| 0.01 | 0.01 | 0.01 | 0.01 |
| 15.6 9.5 7.5 6.4 | 5.4 4.6 | 7.5 6.4 | 7.5 6.4 |
| 2:1 | 2:1 | 2:1 | 2:01 |
| 3-State Output | 3-State Output | 3-State Output | 3-State Output |
| 24 | 24/-24 | 24/-24 | 24 |
| -24 | -24 | ||
| Catalog | Military | HiRel Enhanced Product | Automotive |
| -40 to 85 | -55 to 125 | -40 to 125 -55 to 125 | -40 to 125 |
| SO SOIC SSOP TSSOP VQFN | CFP | TSSOP | SOIC TSSOP |
| 16SO: 80 mm2: 7.8 x 10.2(SO) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 48 mm2: 7.8 x 6.2(SSOP) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16VQFN: 14 mm2: 3.5 x 4(VQFN) | See datasheet (CFP) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 2 | 2 | 2 | 2 |
| 5 | 5 | 5 | 5 |
| 0.75 | 0.75 | 0.75 | 0.75 |
| 2 | 2 | 2 | 2 |
| 无样片 | 无样片 |
