MAX22217 adi
数据:
Four Serial Controlled 36V Half Bridges0.55A DC (TA = 25°C) and 1A Full-Scale Current CapabilityLow RON for High Efficiency High Flexibility: Independent Channel Setting High-Side/Low-Side/Bridge-Tied Load Configuration/Parallel Mode Supported Advanced Control Methods Voltage/Current Drive Regulation Two Levels Sequencer for Power Saving DC-Motor Drive with Current Limiter Dithering Function Ramp up/down Control Demagnetization Voltage Control Integrated Current Sense Diagnostic Functions:Reaction and Travel Time Measurement Detection of Plunger Movements Open-Load Detection Inductance Measurement Digital Current Sense Monitor Full Set of ProtectionsOvercurrent Protection Thermal Protections Undervoltage Lockout The MAX22216/MAX22217 integrate four programmable 36V half-bridges. It is primarily intended to drive inductive loads such as on-off solenoid valves, DC motors, proportional valves, bi-stable valves, relays, etc. The MAX22216 is capable of up to 3.2AFS per half-bridge, whereas the MAX22217 is capable of up to 1AFS per half-bridge. The MAX22216/MAX22217 operate from -40°C to +125°C ambient temperature.The MAX22216/MAX22217 half-bridges support two different use cases. In the first case, configuration settings can be entered through a serial peripheral interface (SPI) and can be changed at any time. Alternatively, settings can be stored in one-time programmable (OTP) registers, which are loaded at power-up. This enables stand-alone operations. Registers are user-programmable. The OTP writing procedure must be executed in a factory under well-controlled temperature and voltage conditions.High-side/low-side single-ended drive operations and bridge-tied load (BTL) configurations are supported. Channel parallelization is also supported.Voltage control, current control, and mixed schemes are supported.In voltage drive regulation mode (VDR mode), the half-bridge output voltage is controlled. Supply variations are internally compensated.In current drive regulation mode (CDR mode), the half-bridge output current is controlled. The current is internally sensed and fed back to the controller for accurate closed-loop regulation. Proportional and integral gains can be configured to optimize steady-state errors and dynamic performance.The MAX22216/MAX22217 integrate functions aimed to optimize solenoid and DC motor drive control. These include a two-level sequencer for power saving, drive signal ramp control (RAMP) for noise reduction, a dither function (DITH) to counteract the effects of static friction and hysteresis, a fast demagnetization feature (DC_H2L) to shorten on-off cycles, and a DC-Motor current limiter for limiting inrush and stall currents.Advanced diagnostic functions are available to improve system reliability and enable predictive maintenance. These include the detection of plunger movement (DPM), inductance measurement, travel time measurement, open-load detection (OL), and real-time current monitoring through a serial Interface.The MAX22216/MAX22217 feature a full set of protection circuits, including overcurrent protection (OCP), overtemperature protection (OVT), and undervoltage lockout (UVM). A fault indicator pin is asserted whenever faults are detected.The MAX22216/MAX22217 are offered in TQFN32 5mm x 5mm packages.APPLICATIONSSolenoid On-Off Valves and RelaysDC Motors Proportional Valves Bi-Stable Latching Solenoid Valves Switching Driver with Real-Time Current Measurement Digital Output InterfaceElectromechanical Motor Brake
