DC1362A-B DC1362A-B评估板
数据:
dc1362a-b DC1362A-B LT3651EUHE-4.1 Demo Board | 6.5V ≤ VIN ≤ 32V, 4A Li-Ion Battery Charger, VOUT =  4.1V @  4A Demonstration circuit 1362A-B (fixed 4.1V output) is a 4A high voltage Li-Ion battery charger featuring the LT3651EUHE-4.1. The LT3651 is a complete, high power Li-Ion battery charger that can operate over a wide input voltage range. The charger is a constant-current, constant-voltage type with a maximum charge current of 4A that can be externally set. A precondition feature trickle charges a low voltage battery and bad battery detection provides a signal if the battery doesn’t respond to preconditioning. The LT3651EUHE is available in a 36-lead (5mm × 6mm) QFN surface mount package with two exposed thermal pads. DC1362A-B
