ESP32开发板单向点对点ESP-NOW无线通信
jf_88434166 来源:jf_88434166 作者:jf_88434166 2026-03-19 09:21 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
@TOC
简介
本例程通过两个ESP32开发板实现单向点对点ESP-NOW无线通信,一个ESP32开发板作为Sender发送方,另一个开发板作为Receiver接收方接收发送方的数据。
在这里插入图片描述
读取ESP32接收方Receiver的MAC地址
#include < WiFi.h >
#include < esp_wifi.h >
void readMacAddress(){
  uint8_t baseMac[6];
  esp_err_t ret = esp_wifi_get_mac(WIFI_IF_STA, baseMac);
  if (ret == ESP_OK) {
    Serial.printf("%02x:%02x:%02x:%02x:%02x:%02xn",
                  baseMac[0], baseMac[1], baseMac[2],
                  baseMac[3], baseMac[4], baseMac[5]);
  } else {
    Serial.println("Failed to read MAC address");
void setup(){
  Serial.begin(115200);
  WiFi.mode(WIFI_STA);
  WiFi.begin();
  Serial.print("[DEFAULT] ESP32 Board MAC Address: ");
  readMacAddress();
void loop(){
在这里插入图片描述
ESP32发送方Sender程序
把接收方ESP32开发板读取到的MAC地址填入以下程序第4行中
#include < esp_now.h >
#include < WiFi.h >
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {0x54, 0x43, 0xb2, 0x7f, 0x00, 0x60};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
  char a[32];
  int b;
  float c;
  bool d;
} struct_message;
// Create a struct_message called myData
struct_message myData;
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("rnLast Packet Send Status:t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void setup() {
  // Init Serial Monitor
  // Set device as a Wi-Fi Station
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK){
    Serial.println("Failed to add peer");
    return;
void loop() {
  // Set values to send
  strcpy(myData.a, "THIS IS A CHAR");
  myData.b = random(1,20);
  myData.c = 1.2;
  myData.d = false;
  // Send message via ESP-NOW
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
  if (result == ESP_OK) {
    Serial.println("Sent with success");
  else {
    Serial.println("Error sending the data");
  delay(2000);
ESP32接收方Receiver程序
#include < WiFi.h >
// Structure example to receive data
// Must match the sender structure
    char a[32];
    int b;
    float c;
    bool d;
} struct_message;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.print("Bytes received: ");
  Serial.println(len);
  Serial.print("Char: ");
  Serial.println(myData.a);
  Serial.print("Int: ");
  Serial.println(myData.b);
  Serial.print("Float: ");
  Serial.println(myData.c);
  Serial.print("Bool: ");
  Serial.println(myData.d);
  Serial.println();
void setup() {
  // Initialize Serial Monitor
  // Init ESP-NOW
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
  esp_now_register_recv_cb(esp_now_recv_cb_t(OnDataRecv));
void loop() {
ESP-NOW通信验证
上传发送方和接收方的程序到ESP32开发板,打开两个串口助手分别显示发送方和接收方的打印结果情况
ESP32发送方:发送结构体struct_message数据并显示发送成功
在这里插入图片描述
ESP32接收方:显示接收到的发送方发送的结构体struct_message的具体数据
在这里插入图片描述
总结
通过以上例程验证了ESP32开发板之间单向点对点的ESP-NOW无线通信,接下来的篇章将继续验证多个的ESP32开发板之间实现一对多的ESP-NOW无线通信。
  • 无线通信
  • 开发板
  • ESP32
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    ESP32/ESP8266开发板单向多对一ESP-NOW无线通信
    本实验通过ESP-NOW无线通信协议实现多个ESP32/ESP 8266开发板ESP32
    的头像 发表于 03-30 10:14 297次阅读
    <b class='flag-5'>ESP32</b>/<b class='flag-5'>ESP</b>8266<b class='flag-5'>开发板</b><b class='flag-5'>单向</b>多对一<b class='flag-5'>ESP-NOW</b><b class='flag-5'>无线通信</b>
    ESP32/ESP8266开发板单向一对多ESP-NOW无线通信
    通过ESP-NOW无线通信协议实现ESP32开发板向多个ESP32/ESP 8266
    的头像 发表于 03-13 09:23 373次阅读
    <b class='flag-5'>ESP32</b>/<b class='flag-5'>ESP</b>8266<b class='flag-5'>开发板</b><b class='flag-5'>单向</b>一对多<b class='flag-5'>ESP-NOW</b><b class='flag-5'>无线通信</b>
    ESP32/ESP8266开发板ESP-NOW无线通信
    ESP-NOW 是由Espressif开发的基于数据链路层的无线通信协议,它将五层 OSI 上层协议精简为一层,数据传输时无需依次经过网络层、传输层、会话层、表示层、应用层等复杂的层级,也无需层层
    的头像 发表于 02-27 20:03 408次阅读
    <b class='flag-5'>ESP32</b>/<b class='flag-5'>ESP</b>8266<b class='flag-5'>开发板</b><b class='flag-5'>ESP-NOW</b><b class='flag-5'>无线通信</b>
    ESP32-C5系列】WT9932C5-TINY开发板上手指南
    实现了强劲性能与丰富功能的平衡。开发板主频高达240MHz,依托ESP32-C5升级的无线能力,支持Wi-Fi6(802.11ax)与蓝牙5.3双模通信,相比前代
    的头像 发表于 02-26 18:05 662次阅读
    【<b class='flag-5'>ESP32</b>-C5系列】WT9932C5-TINY<b class='flag-5'>开发板</b>上手指南
    ESP32-C2系列】WT9932C2-TINY开发板上手指南
    体积内实现了强劲性能与丰富功能的平衡。开发板主频高达120MHz,支持蓝牙与Wi-Fi双模无线通信,可无缝适配智能家居、低功耗物联网终端等场景。硬件设计上,不仅将所
    的头像 发表于 02-25 18:25 427次阅读
    【<b class='flag-5'>ESP32</b>-C2系列】WT9932C2-TINY<b class='flag-5'>开发板</b>上手指南
    ESP32-P4系列】WT9932P4-MINI开发板上手指南
    开发板介绍ESP32-P4-MINI开发板是深圳市启明云端有限公司推出的,基于WT0132P4-A1核心设计的多媒体开发板。WT0132P
    的头像 发表于 02-12 18:16 558次阅读
    【<b class='flag-5'>ESP32</b>-P4系列】WT9932P4-MINI<b class='flag-5'>开发板</b>上手指南
    ESP32-C3】WT9932C3-TINY开发板规格书
    体积内实现了强劲性能与丰富功能的平衡。开发板主频高达160MHz,支持蓝牙与Wi-Fi双模无线通信,可无缝适配智能家居、低功耗物联网终端等场景。硬件设计上,不仅将
    的头像 发表于 02-11 18:04 996次阅读
    【<b class='flag-5'>ESP32</b>-C3】WT9932C3-TINY<b class='flag-5'>开发板</b>规格书
    ESP32-C5系列】WT9932C5-TINY开发板规格书
    了强劲性能与丰富功能的平衡。开发板主频高达240MHz,依托ESP32-C5升级的无线能力,支持Wi-Fi6(802.11ax)与蓝牙5.3双模通信,相比前代吞吐
    的头像 发表于 02-09 18:20 799次阅读
    【<b class='flag-5'>ESP32</b>-C5系列】WT9932C5-TINY<b class='flag-5'>开发板</b>规格书
    ESP32-P4系列】WT9932P4-MINI开发板规格书
    的头像 发表于 02-03 18:14 681次阅读
    【<b class='flag-5'>ESP32</b>-P4系列】WT9932P4-MINI<b class='flag-5'>开发板</b>规格书
    ESP32-P4全功能开发板ESP32-P4-TINY开发板该怎么选?看这篇就够了!
    启明云端基于乐鑫科技ESP32-P4芯片设计了多款开发板,这些开发板有什么区别?基于应用场景如何选择?本期,我们聚焦两款代表性产品:WT99P4C5-S1开发板与WT9932P4-TI
    的头像 发表于 12-09 18:02 1441次阅读
    <b class='flag-5'>ESP32</b>-P4全功能<b class='flag-5'>开发板</b>和<b class='flag-5'>ESP32</b>-P4-TINY<b class='flag-5'>开发板</b>该怎么选?看这篇就够了!
    ESP32ESP-NOW通讯踩坑记
    1、背景前段时间看到乐鑫推出了一种很有意思的Wi-Fi通讯协议,它允许设备在无连接的时候进行直接通讯。乐鑫对它的概述如下:“ESP-NOW是一种由乐鑫公司定义的无连接Wi-Fi通信协议。在ESP-NOW中,应用程序数据被封装在
    的头像 发表于 09-13 10:03 3022次阅读
    <b class='flag-5'>ESP32</b>的<b class='flag-5'>ESP-NOW</b>通讯踩坑记
    ESP32-P4-MINI开发板开箱和上手指南来了!速速码住!
    上期“梦中情ESP32-P4-MINI开发板一出就备受青睐这期我们立马就端着开箱和上手指南来了!不用惊叹,我们就是这么迅速,请把“启明云端权威”打在公屏上好嘛!开箱展示拿到
    的头像 发表于 07-25 18:02 2708次阅读
    <b class='flag-5'>ESP32</b>-P4-MINI<b class='flag-5'>开发板</b>开箱和上手指南来了!速速码住!
    ESP32开发板元件资料
    ESP32开发板元件
    发表于 07-21 14:47 17次下载
    ESP32-P4 C5开发板烧录小智全流程!速看!
    没错,你没有看错!我们带着WT99P4C5-S1开发板烧录小智全流程走来了!开发板搭载乐鑫科技ESP32-P4和ESP32-C5芯片,代码完全开源,支持灵活二次
    的头像 发表于 07-04 18:03 3196次阅读
    <b class='flag-5'>ESP32</b>-P4 C5<b class='flag-5'>开发板</b>烧录小智全流程!速看!
    ESP32-S3开发板烧录小智AI系统全流程指南
    在AI语音交互领域不断发展的今天,开发者们对于功能强大、开源灵活的开发板需求日益增长。今天,我们就来详细了解一下ESP32AgentDevKit烧录小智的全流程,这款搭载乐鑫科技ESP32
    的头像 发表于 06-16 18:01 9137次阅读
    <b class='flag-5'>ESP32</b>-S3<b class='flag-5'>开发板</b>烧录小智AI系统全流程指南
