ESP32/ESP8266开发板单向多对一ESP-NOW无线通信
jf_88434166 来源:jf_88434166 作者:jf_88434166 2026-03-30 10:14 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
简介
本实验通过ESP-NOW无线通信协议实现多个ESP32/ESP 8266开发板向ESP32开发板发送数据。例如可以应用于从多个远程传感器上收集数据。
在这里插入图片描述
读取ESP32/ESP8266接收方Receiver的MAC地址
读取ESP32开发板的代码
#ifdef ESP32
  #include < WiFi.h >
  #include < esp_wifi.h >
#else
  #include < ESP8266WiFi.h >
#endif
void setup(){
  Serial.begin(115200);
  Serial.print("ESP Board MAC Address: ");
  #ifdef ESP32
    WiFi.mode(WIFI_STA);
    WiFi.STA.begin();
    uint8_t baseMac[6];
    esp_err_t ret = esp_wifi_get_mac(WIFI_IF_STA, baseMac);
    if (ret == ESP_OK) {
      Serial.printf("%02x:%02x:%02x:%02x:%02x:%02xn",
                    baseMac[0], baseMac[1], baseMac[2],
                    baseMac[3], baseMac[4], baseMac[5]);
    } else {
      Serial.println("Failed to read MAC address");
  #else
    Serial.println(WiFi.macAddress());
  #endif
void loop(){
通过串口打印读取到接收方ESP32开发板1的MAC地址为:54:43:b2:7f:00:60
在这里插入图片描述
ESP32/ESP8266发送方Sender程序
把读取到的接收方的MAC地址填入到uint8_t broadcastAddress[]数组中,并修改结构体的中myData.id的值,ESP32开发板1程序中填入myData.id = 1,ESP32开发板2程序中填入myData.id = 2,ESP32开发板3程序中填入myData.id = 3,接收方以此来分辨是哪一个ESP32开发板发过来的数据。
#include < esp_now.h >
#include < WiFi.h >
// REPLACE WITH THE RECEIVER'S MAC Address
uint8_t broadcastAddress[] = {0x54, 0x43, 0xb2, 0x7f, 0x00, 0x60};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
    int id; // must be unique for each sender board
    int x;
    int y;
} struct_message;
// Create a struct_message called myData
struct_message myData;
// Create peer interface
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("rnLast Packet Send Status:t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void setup() {
  // Init Serial Monitor
  // Set device as a Wi-Fi Station
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  // Once ESPNow is successfully Init, we will register for Send CB to
  // get the status of Trasnmitted packet
  esp_now_register_send_cb(OnDataSent);
  // Register peer
  memcpy(peerInfo.peer_addr, broadcastAddress, 6);
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // Add peer
  if (esp_now_add_peer(&peerInfo) != ESP_OK){
    Serial.println("Failed to add peer");
    return;
void loop() {
  // Set values to send
  myData.id = 1;
  myData.x = random(0,50);
  myData.y = random(0,50);
  // Send message via ESP-NOW
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
  if (result == ESP_OK) {
    Serial.println("Sent with success");
  else {
    Serial.println("Error sending the data");
  delay(10000);
ESP32/ESP8266接收方Receiver程序
#include < WiFi.h >
// Structure example to receive data
// Must match the sender structure
  int id;
  int x;
  int y;
}struct_message;
// Create a structure to hold the readings from each board
struct_message board1;
struct_message board2;
struct_message board3;
// Create an array with all the structures
struct_message boardsStruct[3] = {board1, board2, board3};
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac_addr, const uint8_t *incomingData, int len) {
  char macStr[18];
  Serial.print("Packet received from: ");
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  Serial.println(macStr);
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.printf("Board ID %u: %u bytesn", myData.id, len);
  // Update the structures with the new incoming data
  boardsStruct[myData.id-1].x = myData.x;
  boardsStruct[myData.id-1].y = myData.y;
  Serial.printf("x value: %d n", boardsStruct[myData.id-1].x);
  Serial.printf("y value: %d n", boardsStruct[myData.id-1].y);
  Serial.println();
void setup() {
  //Initialize Serial Monitor
  //Set device as a Wi-Fi Station
  //Init ESP-NOW
    return;
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info
  esp_now_register_recv_cb(esp_now_recv_cb_t(OnDataRecv));
void loop() {
  // Acess the variables for each board
  /*int board1X = boardsStruct[0].x;
  int board1Y = boardsStruct[0].y;
  int board2X = boardsStruct[1].x;
  int board2Y = boardsStruct[1].y;
  int board3X = boardsStruct[2].x;
  int board3Y = boardsStruct[2].y;*/
  delay(10000);
ESP-NOW通信验证
在这里插入图片描述
分别给左边的3个ESP32开发板下载好发送方Sender程序,给右边的ESP32开发板下载好接收方Receiver程序
若接收方接收到数据串口会打印出接收到对应的ESP32开发板的ID号和ESP32开发板的两个随机数
在这里插入图片描述
若发送方数据发送成功串口会打印出数据发送完成,数据接收成功
在这里插入图片描述
若发送方数据发送成功串口会打印出数据发送完成,数据接收失败
在这里插入图片描述
总结
通过以上例程验证了ESP32开发板之间单向多对一的ESP-NOW无线通信。
  • 无线通信
  • 开发板
  • ESP8266
  • ESP32
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    ESP32开发板单向点对点ESP-NOW无线通信
    本例程通过两个ESP32开发板实现单向点对点ESP-NOW无线通信
    的头像 发表于 03-19 09:21 432次阅读
    <b class='flag-5'>ESP32</b><b class='flag-5'>开发板</b><b class='flag-5'>单向</b>点对点<b class='flag-5'>ESP-NOW</b><b class='flag-5'>无线通信</b>
    ESP32/ESP8266开发板单向ESP-NOW无线通信
    通过ESP-NOW无线通信协议实现ESP32开发板向多个ESP32/ESP
    的头像 发表于 03-13 09:23 436次阅读
    <b class='flag-5'>ESP32</b>/<b class='flag-5'>ESP8266</b><b class='flag-5'>开发板</b><b class='flag-5'>单向</b><b class='flag-5'>一</b>对<b class='flag-5'>多</b><b class='flag-5'>ESP-NOW</b><b class='flag-5'>无线通信</b>
    ESP32/ESP8266开发板ESP-NOW无线通信
    ESP-NOW 是由Espressif开发的基于数据链路层的无线通信协议,它将五层 OSI 上层协议精简为层,数据传输时无需依次经过网络层、传输层、会话层、表示层、应用层等复杂的层级
    的头像 发表于 02-27 20:03 466次阅读
    <b class='flag-5'>ESP32</b>/<b class='flag-5'>ESP8266</b><b class='flag-5'>开发板</b><b class='flag-5'>ESP-NOW</b><b class='flag-5'>无线通信</b>
    ESP32-P4系列】WT9932P4-MINI开发板上手指南
    开发板介绍ESP32-P4-MINI开发板是深圳市启明云端有限公司推出的,基于WT0132P4-A1核心设计的多媒体开发板。WT0132P
    的头像 发表于 02-12 18:16 623次阅读
    【<b class='flag-5'>ESP32</b>-P4系列】WT9932P4-MINI<b class='flag-5'>开发板</b>上手指南
    ESP32-P4系列】WT9932P4-MINI开发板规格书
    的头像 发表于 02-03 18:14 736次阅读
    【<b class='flag-5'>ESP32</b>-P4系列】WT9932P4-MINI<b class='flag-5'>开发板</b>规格书
    无需安装!在浏览器里就能玩转ESP32/ESP8266,这个神器绝了!
    无需安装!在浏览器里就能玩转ESP32/ESP8266,这个神器绝了!【往期精选】十年嵌入式最深的痛,不是Bug,而是抓不到日志!vivo宣布原生支持HomeAssistant生态设备接入(含
    的头像 发表于 01-10 10:01 1890次阅读
    无需安装!在浏览器里就能玩转<b class='flag-5'>ESP32</b>/<b class='flag-5'>ESP8266</b>,这个神器绝了!
    乐鑫科技ESP-AMP框架详解!两款已支持的ESP32-P4C5开发板推荐!启明云端乐鑫科技代理
    操作系统,并提供完整的核间通信机制。启明云端旗两款高性能开发板——WT99P4C5-S1与WTDKP4C5-S1,搭载乐鑫科技ESP32-P4芯片和ESP32-C5芯
    的头像 发表于 12-18 18:02 2412次阅读
    乐鑫科技<b class='flag-5'>ESP</b>-AMP框架详解!两款已支持的<b class='flag-5'>ESP32</b>-P4C5<b class='flag-5'>开发板</b>推荐!启明云端乐鑫科技代理
    ESP32-P4全功能开发板ESP32-P4-TINY开发板该怎么选?看这篇就够了!
    启明云端基于乐鑫科技ESP32-P4芯片设计了多款开发板,这些开发板有什么区别?基于应用场景如何选择?本期,我们聚焦两款代表性产品:WT99P4C5-S1开发板与WT9932P4-TI
    的头像 发表于 12-09 18:02 1514次阅读
    <b class='flag-5'>ESP32</b>-P4全功能<b class='flag-5'>开发板</b>和<b class='flag-5'>ESP32</b>-P4-TINY<b class='flag-5'>开发板</b>该怎么选?看这篇就够了!
    晶科鑫 | 国产26MHz晶振匹配Espressif(乐鑫) ESP8285/ESP8266芯片案例
    本,两者可以共用同套SDK,只是ESP8285内部集成了1MBFlash,SPIMode设置为DOUT,而ESP8266则需要外接Flash,并且是Din模式。除此之外,ESP828
    的头像 发表于 11-21 15:37 5172次阅读
    晶科鑫 | 国产26MHz晶振匹配Espressif(乐鑫) <b class='flag-5'>ESP</b>8285/<b class='flag-5'>ESP8266</b>芯片案例
    ESP8266ESP32开发板常见的2种下载方式
    ESP32ESP8266是性价比很高而且使用较为广泛的的Wi-Fi模块,在物联网(IoT)领域的DIY项目中可以首先考虑这2款产品。 两款芯片都属于32位处理器。ESP32是低功耗双核80MHz
    的头像 发表于 11-10 20:30 1638次阅读
    <b class='flag-5'>ESP8266</b>和<b class='flag-5'>ESP32</b><b class='flag-5'>开发板</b>常见的2种下载方式
    ESP8266全IO口引出,直接下载无需复位! ESP32功能框图 基于arduino的ESP32/ESP8266开发环境搭建 1.在a
    发表于 10-24 18:04
    ESP32ESP-NOW通讯踩坑记
    1、背景前段时间看到乐鑫推出了种很有意思的Wi-Fi通讯协议,它允许设备在无连接的时候进行直接通讯。乐鑫对它的概述如下:“ESP-NOW种由乐鑫公司定义的无连接Wi-Fi通信协议
    的头像 发表于 09-13 10:03 3091次阅读
    <b class='flag-5'>ESP32</b>的<b class='flag-5'>ESP-NOW</b>通讯踩坑记
    ESP32-P4-MINI开发板开箱和上手指南来了!速速码住!
    上期“梦中情ESP32-P4-MINI开发板出就备受青睐这期我们立马就端着开箱和上手指南来了!不用惊叹,我们就是这么迅速,请把“启明云端权威”打在公屏上好嘛!开箱展示拿到
    的头像 发表于 07-25 18:02 2767次阅读
    <b class='flag-5'>ESP32</b>-P4-MINI<b class='flag-5'>开发板</b>开箱和上手指南来了!速速码住!
    ESP32开发板元件资料
    ESP32开发板元件
    发表于 07-21 14:47 17次下载
    ESP32-S3开发板烧录小智AI系统全流程指南
    在AI语音交互领域不断发展的今天,开发者们对于功能强大、开源灵活的开发板需求日益增长。今天,我们就来详细了解ESP32AgentDevKit烧录小智的全流程,这款搭载乐鑫科技
    的头像 发表于 06-16 18:01 9242次阅读
    <b class='flag-5'>ESP32</b>-S3<b class='flag-5'>开发板</b>烧录小智AI系统全流程指南
