背景
在我们系统中,承接多种行业,多种商家的,多个业务条线,不同场景的的不同业务诉求,在实现上将个性和通用字段隔离,通用字段是所有条线通用逻辑所共用的标准字段,对于个别条线的个性化诉求,则通过个性化扩展字段来实现。
通用字段,作用于通用逻辑,所有条线走到相应功能时,会对通用字段读写。而对于个性扩展字段而言,只有用到个性化功能时,才会对个性化扩展字段进行赋值。在数据库持久化存储上,用不到该个性化扩展字段时,该字段无需存储,不占用额外存储空间。
在表结构上,使用JSON类型字段进行存储。在日常扩展字段的开发过程中,不可避免的用到JSON函数进行字段处理。
常用JSON函数一览
| Name | Description |
| -> | Return value from JSON column after evaluating path; equivalent to JSON_EXTRACT(). |
| ->> | Return value from JSON column after evaluating path and unquoting the result; equivalent to JSON_UNQUOTE(JSON_EXTRACT()). |
| JSON_APPEND() | Append data to JSON document |
| JSON_ARRAY() | Create JSON array |
| JSON_ARRAY_APPEND() | Append data to JSON document |
| JSON_ARRAY_INSERT() | Insert into JSON array |
| JSON_CONTAINS() | Whether JSON document contains specific object at path |
| JSON_CONTAINS_PATH() | Whether JSON document contains any data at path |
| JSON_DEPTH() | Maximum depth of JSON document |
| JSON_EXTRACT() | Return data from JSON document |
| JSON_INSERT() | Insert data into JSON document |
| JSON_KEYS() | Array of keys from JSON document |
| JSON_LENGTH() | Number of elements in JSON document |
| JSON_MERGE() | Merge JSON documents, preserving duplicate keys. Deprecated synonym for JSON_MERGE_PRESERVE() |
| JSON_MERGE_PATCH() | Merge JSON documents, replacing values of duplicate keys |
| JSON_MERGE_PRESERVE() | Merge JSON documents, preserving duplicate keys |
| JSON_OBJECT() | Create JSON object |
| JSON_PRETTY() | Print a JSON document in human-readable format |
| JSON_QUOTE() | Quote JSON document |
| JSON_REMOVE() | Remove data from JSON document |
| JSON_REPLACE() | Replace values in JSON document |
| JSON_SEARCH() | Path to value within JSON document |
| JSON_SET() | Insert data into JSON document |
| JSON_STORAGE_SIZE() | Space used for storage of binary representation of a JSON document |
| JSON_TYPE() | Type of JSON value |
| JSON_UNQUOTE() | Unquote JSON value |
| JSON_VALID() | Whether JSON value is valid |
JSON字段实现项目场景诉求典型案例分析
JSON字段对我们系统来说并不陌生,有不少场景使用,下面有一些典型的使用场景案例先放出来作为JSON字段项目使用背景铺垫一下。
扩展字段的存储和查询
动态扩展查询案例
在二手库或逆向条件,有比较多的扩展属性,其他条线缺没有这些属性值,这些属性以JSON扩展的方式存储。
下面是一个JSON扩展字段的JSON数据示例:
"ppCode": "PPDA4302865239B10F",
"zoneNo": "STAGE-OUTBOUND",
"zoneName": "出库暂存区",
"zoneType": "t",
"extendMap": {
"cid1": 13765,
"cid2": 14192,
"cid3": 14533,
"deptId": "1",
"jdFlag": 1,
"symbol": 300,
"brandId": 52368,
"cbjPrice": 2034,
"salesPin": "xumingchen",
"commonType": 0,
"wareSource": 100,
"orderSource": "it100",
"supplierCode": "lgde",
"outTransferId": "1284009718",
"inboundSourceType": 100,
"purchaseChannelId": "1001"
"storeCode": "",
"sourceModule": "wms-pick",
"isolationZone": false,
"stageZoneType": "OUTBOUND"
这些扩展字段支持作为查询条件过滤库存,用于出库建单。
在服务层面为了支持动态增减的属性条件,条件字段定义为Map类型,与 JSON 字段中的 extendMap 所对应。
list查询条件的特殊预处理
SQL层面的动态查询效果:
元素包含条件使用案例
设备组条件
批属性条件
序列号条件
数值管理深度剖析案例
案例背景
在现有的场景中,目前仅华冠场景支持重量库存,其他条线暂无库存管理。在本案例中,重量库存通过个性化扩展字段实现,JSON类型。
JSON类型的字段名是 extend_content,其中重量字段 stockWeight 的 JSON path是 $.stockInfo.stockWeight 。
stockInfo 的内容示例如下:
"businessNo": "OT2008735812539129856",
"stockWeight": 630,
"businessType": "WMS_PICK",
"businessTypeName": "出库拣货"
增减重量库存
单行更新
通过CASE WHEN THEN 方式批量更新JSON字段中的重量库存
剥茧第一层
在调试中,发现JSON字段,如果想要通过 json_set 赋值,必须依赖于该字段不能为null,如果json_set 该JSON字段值为null,则更新不上,不会产生SQL语法错误。
对于存量的历史null值字段统计,并做一次初始化。
初始化历史数据
统计JSON字段extend_content值为null 的数据
将 extend_content 为 null 的进行初始化
统计JSON字段extend_content值不为null,但其中的stockInfo为null的数据
将 extend_content.stockInfo 为 null 的数据进行初始化
对存量的历史数据初始化完毕,考虑到某些场景可能还会持续产生 JSON 字段 null值情况,考虑在代码中进行兼容,如果想在 JSON 字段中进行 json_set,SQL进行检查并自动进行前置初始化。
以上SQL,通过JSON_OBJECT函数将null值的JSON字段,初始化为一个空JSON对象,肉眼看上去是 {}。
剥茧第二层
除了上面历史null值的JSON字段外,还发现一个更为复杂的场景,JSON字段更新前不为null,但是本次赋值更新操作却导致JSON字段整体变成了null,匪夷所思!
单行更新方式因为是一次是更新一行,没有问题。
批量更新,如果所有的明细stockWeight字段都有值,更新也没问题。如果一次批量更新的明细中,有的stockWeight字段有值,有的没有值,则更新会有问题,不会出现SQL语法错误,但是整个extend_content JSON字段会被错误地更新为null。
在测试环境中,调试的一个入参如下:
"requestHeader": {
"sourceModule": "inventory",
"requestIp": "11.50.45.137",
"warehouseNo": "6_6_618",
"businessType": "INV-CHANGE-PROFIT-LOSS",
"businessTypeName": "盘盈亏",
"businessNo": "CP2009231067168407553",
"uuid": "wms.inv.change.profit.6_6_618.CP2009231067168407553.2009231067554283520.12",
"operator": "guozhongqiang5"
"increaseStockDetailList": [
"detailBusinessNo": "DPPT20092299369586442242",
"stockLocationIndicator": {
"locationNo": "01",
"containerLevel1": "",
"containerLevel2": ""
"stockSkuIndicator": {
"sku": "EMG172002001",
"lotNo": "-1",
"skuLevel": "100",
"packCode": "8c59689e8972a14e4883b0ea755b3702",
"ownerNo": "EBU4398046536982"
"increaseOperateType": "normalIncrease",
"stockQty": 1.0000,
"recommendLocationNo": "",
"externalNo": "CP2009231067168407553",
"uniqueStockList": [],
"reason": {}
"detailBusinessNo": "DPPT2009229936958644224",
"locationNo": "01",
"sku": "EMG172002003",
"lotNo": "-1",
"skuLevel": "100",
"stockQty": 0.0000,
"stockWeight": 3000,
"reason": {}
我们可以看到,上面这个入参有两个明细,对应的SKU分别是EMG172002001 和 EMG172002003。第一个明细只有stockQty字段无stockWeight字段,第二个同时有stockQty字段,和stockWeight字段,stockWeight值为 3000。
此时,批量更新形成的SQL如下:
UPDATE
st_stock
set
stock_qty =
case
WHEN deleted = 0
AND warehouse_no = '6_6_618'
AND id = 2008872347100020736
AND status = 0
THEN stock_qty + 1.0000
WHEN deleted = 0
AND id = 2008872388812374016
AND status = 0
THEN stock_qty + 0.0000
end,
extend_content =
case
WHEN deleted = 0
AND status = 0
THEN JSON_SET(COALESCE(extend_content, '{}'), '$.stockInfo', COALESCE(JSON_EXTRACT(extend_content, '$.stockInfo'), JSON_OBJECT()))
ELSE extend_content
end,
extend_content =
case
WHEN deleted = 0
AND status = 0
THEN json_set(extend_content, '$.stockInfo.stockWeight', IFNULL(extend_content ->> '$.stockInfo.stockWeight', 0) + IFNULL(3000.0, 0))
end,
update_time = now(),
version = version + 1,
update_user = 'guozhongqiang5',
extend_content = json_set(extend_content, '$.stockInfo.businessType', 'INV-CHANGE-PROFIT-LOSS', '$.stockInfo.businessTypeName', '盘盈亏', '$.stockInfo.businessNo', 'CP2009231067168407553333')
WHERE
deleted = 0
AND status = 0
or
deleted = 0
AND status = 0
问题出现下图圈红的部分:
在上面的场景中,一次批量更新有两个明细,其中一个因为stockWeight为null,不会被动态拼接到SQL中,这个无对应的 WHEN THEN 则 extend_content 被置为null,另一个明细因为有 WHEN THEN 则赋值正常。
此时直观的想法是,既然因为stockWeight为null的明细走不上 WHEN THEN ,何不通过 ELSE 赋值为extend_content 本身来解决呢。按此思路进行代码调整如下:
调试明细stockWeigh不为空,验证通过。
剥茧第三层
但是,当所有明细stockWeight为null的时候,因为 ELSE extend_content 在 if条件满足的时候才会动态拼接,当,此时 WHEN THEN 和 ELSE都不会拼接进去,语法不通过。
那么,把 ELSE extend_content 从 if 条件判断拿出来,放在 end的前面总可以了吧。
这里借助 foreach 的 close 来拼接 ELSE extend_content 语句。
在测试环境验证时,当更新入参至少一个明细中的 stockWeight 不为null时,确实没问题。当所有明细的stockWeight都为null时,新的问题来了,报错信息及分析过程如下:
### The error occurred while setting parameters ### SQL: UPDATE st_stock set stock_qty=case WHEN deleted = 0 AND warehouse_no = ? AND id = ? and stock_qty >= ? * -1 THEN stock_qty + ? WHEN deleted = 0 AND warehouse_no = ? AND id = ? and stock_qty >= ? * -1 THEN stock_qty + ? end, diff_qty=case WHEN deleted = 0 AND warehouse_no = ? AND id = ? and diff_qty >= ? * -1 THEN diff_qty + ? WHEN deleted = 0 AND warehouse_no = ? AND id = ? and diff_qty >= ? * -1 THEN diff_qty + ? end, extend_content=case ELSE extend_content end, extend_content=case ELSE extend_content end, update_time = now() , version = version + 1 , update_user = ? , extend_content = json_set(extend_content, ?, ?, ?, ?, ?, ?) WHERE ( deleted = 0 AND warehouse_no = ? AND id = ? and diff_qty >= ? * -1 AND status = 0 ) or ( deleted = 0 AND warehouse_no = ? AND id = ? and diff_qty >= ? * -1 AND status = 0 ) /* [SQLMarking] statementId: com.jdwl.wms.stock.infrastructure.jdbc.main.dao.StockOperationDao.simpleDecreaseDiffQty */ ### Cause: com.jdbc.exceptions.jdbc4.SQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your SQL server version for the right syntax to use near 'ELSE extend_content end, extend_content=case ELSE extend_content' at line 36 ; bad SQL grammar []; nested exception is com.sql.jdbc.exceptions.jdbc4.SQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your SQL server version for the right syntax to use near 'ELSE extend_content end,
入参
"requestHeader": {
"requestIp": "11.158.12.73",
"businessType": "INV-PROFIT-LOSS-TRANSFER-STOCK-MATCH",
"businessTypeName": "盘盈、盘亏单预占转移",
"businessNo": "CL2009892868717576192",
"uuid": "wms.inv.change.lock.transfer.loss.6_6_618.2009892868977623040.0",
"stockLockTransformType": "difference2Change",
"stockLockTransformDetailList": [
"srcBusinessNo": "DPPT2009892261415911424",
"destBusinessNo": "CL2009892868717576192",
"sku": "EMG172002002",
"lotNo": "-1",
"skuLevel": "100",
"locationNo": "01",
"qty": 2
"sku": "EMG172002004",
"lotNo": "-1",
"skuLevel": "100",
"locationNo": "01",
"qty": 4
"serialLockTransformDetailList": [
入参本身没什么问题,是符合要求的入参,从本次需求的特征上来看只是没有重量字段,重量字段非必填,也不是必须的,在很多场景下也不涉及重量库存的变化。
数据
数据库中的待更新数据本身也没有问题。
到这里,已经确认入参是正常场景,待更新数据也没问题,是SQL本身存在问题。
< trim prefix="extend_content=case" suffix="end," >
< foreach collection="list" item="item" index="index" close="ELSE extend_content" >
< if test="item.stockWeight != null and item.stockWeight != 0" >
WHEN
< include refid="simpleCommonIncreaseClauseOfItem"/ >
THEN json_set(extend_content, #{item.stockWeightJsonPath, jdbcType=VARCHAR}, IFNULL(extend_content ->> #{item.stockWeightJsonPath, jdbcType=VARCHAR}, 0) + IFNULL(#{item.stockWeight, jdbcType=DECIMAL}, 0))
< /if >
< /foreach >
< /trim >
结合代码来看,入参stockWeight为null,则 if 条件里的 WHEN THEN 拼不进去,但 close 部分的 ELSE extend_content 可以拼入,结合前面prefix的 extend_content=case 和 suffix 的 end, 连在一起就是:
显然,这个语法不通过的。
解决方法也比较简单,就是把 ELSE 语句改成 WHEN THEN 语句,具体如下:
这样即使if语句不拼接进去,整体拼出来的语句如下,也是符合预期的:
extend_content=case WHEN 1=1 THEN extend_content end,
至此,批量更新所有明细全有stockWeight,全无stockWeight,部分有部分无stockWeight的场景,均已支持完毕。
再来一层
回过头看,还有另外一个思路处理更为简单,不用 CASE WHEN THEN 方式新写一个批量更新方法:
这种批量更新方式,依赖于开启 allowMultiQueries :
不禁感慨,条条大路通罗马,并非所有的路都一帆风顺,但我们终究抵达终点。
数据库
7文章
4078浏览量
68524 -
JSON
129浏览量
7808
深度解读MySQL数据库备份恢复策略
不用编程不用联网,快速实现PLC与数据库双向数据通讯的案例
2025开放原子开发者大会AI时代数据库创新实践分论坛成功举办
数据库慢查询分析与SQL优化实战技巧
数据库性能优化指南
数据库数据恢复—服务器异常断电导致Oracle数据库故障的数据恢复案例
三款主流国产数据库的技术特点
企业级MySQL数据库管理指南
oracle数据恢复—oracle数据库误执行错误truncate命令如何恢复数据?
抽丝剥茧探穷境!一次数据库JSON字段的深度使用实践
