应用指导 | CGAN003: GaN switching behavior analysis
云镓半导体 2025-11-11 13:45 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
众所周知,GaN 功率器件具有传统功率器件无可比拟的性能优势,如大幅提升的开关速度和显著降低的开关损耗,从而提供更优的整体效率,这使得GaN器件在高频、高效率的应用中展现出明显优势。我们的应用指导将帮助客户更好得使用云镓的 GaN 器件,更大限度去挖掘云镓的 GaN 器件的能力。本次发布云镓应用手册第三弹: GaN switching behavior analysis。此外,客户可以通过云镓半导体官方网站或者微信公众号了解到更多云镓 GaN 产品资讯和相关技术文档。
Part 1 : Overview ofDPT
01
Why do we need DPT to measure GaN?
Whydo we need double pulse tester to measure GaN FETs?
Extracting switching parameters (ton, toff, tr, tf)
Extractingswitching loss (Eon, Eoff)
Emulatingsystem behavior, e.g. turn-off drain spike, switching time and etc.
Evaluating dynamic performance, e.g. dynamic Ron, D-HTOL, switching SOA, and etc.
Noneed of high-power equipment, low-cost scheme
02
An example of DPT-650V/30mΩ CloudSemi GaN
Part 2 : Detailed analysis
01
1stpulse turn-on: zero-current switching
Stageof start-up,zero-currentturn-on (capacitive-load switching):
  • Vdsof rectifier GaN:Vbus→ 0; Vdsof synchronous GaN: 0 → Vbus
  • Thesetup can be treated as a capacitive-load switching:
  • Oscilloscope-captured Ids comes from charging Coss of Syn GaN: Ids = C(Vbus-Vds)*dv/dt
  • DischargingCossof Rec GaN cannot be directlycaptured by oscilloscope: ICoss= Coss*dv/dt
  • Current through Rec GaN channel: Ich, rec = Ids + Coss*dv/dt
02
HSW turn-on transient: Vgoff to Vth
t0~t1,gate drive charges Ciss of Rec GaN:
Vgsof Rec GaN rises to Vth. No current flowsthrough RecGaN.
Loadcurrent flows through inductor and Syn GaN.
UntilVgsof Rec GaN reach to its Vth, loadcurrent starts to commutate and flow through it.
03
HSW turn-on transient: current commutation
t1~t2,current commutation:
AsVgsof Rec GaN reaches Vth,current starts to flow through Rec GaN. Load current gradually commutates fromSyn GaN to Rec GaN, as Vgsincreases;
Duringcurrent commutation, the gate driver charges Ciss until Rec GaN has currentcapability of IL.[Ids|(Vgs=Vgp) = IL]
WhenVgs= Vgp (Miller plateau, = Vth + IL/gm),all the inductive-load current flows through the Rec GaN.
Inthis duration, Rec GaN Idsoverlaps with Vds, andI-Voverlap lossdominates and can be calculated by integrating I&V.
04
HSW turn-on transient: voltage commutation
t2~t3,voltage commutation:
AsVgsof Rec GaN reaches Vgp, allthe load current flows through Rec GaN;
Then,RecGaN Cossstarts to discharge from Vbusto Von& SynGaN Cossstarts to charge to Vbus
RecGaN Cossdischarging cannot be captured,but SynGaN Cosscharging can be recognized from Ids waveform
Duringthis duration, the loss on Rec GaN consists of 2main parts:
I-V overlap loss
Cap loss fromSyn/Rec GaN: Vbus*Qoss
GaN features much lower Qossandswitching loss Psw comparing to Si SJ
05
HSW turn-on transient: gate over-drive
t3~t4,gate over-drive to make GaN fully turn-on:
Gatedriver continue to charge Ciss fromVgp to Vdrive (e.g. 6V), making GaN FET fullyturn-on
Von= IL* Rdson (Vgs= Vdrive). Therecommended gate drive voltage for CloudSemi E-mode GaNis ~6.0V.
Aftert4, inductive load will continue to excite, following dIL = Vbus/L * dt
Conductionloss on Rec GaN FET dominates in this duration
Comparing to Si SJ, GaN FET features much lower gate charge QG
06
Turn-on period: excitation
t4~t5,inductive load excitation:
dIL = Vbus/L *dt, Ids = IL
Cissstops charging
Currentflowingthrough GaN channel gradually increases
RecGaN FET works in linear region.
07
HSW turn-off transient: VGS → Vgp
t5~t6, Ciss starts discharging:
Rec GaN Ciss starts to discharge, until GaN enters saturation mode (Vgs= Vgp, Idsat = IL).
Here,Vgp =Vth + IL/gm
RecGaN works from linear region to saturation region
08
HSW turn-off transient: voltage commutation
t6~t7,voltage commutation (Rec GaN Vdsrises to Vbus):
Loadcurrent charges the switching node (charging CossofRec GaN, discharging Cossof Syn GaN)
Parameterof Qossis crucial, and determinescharging/discharging speed (i.e. switching speed)
Powerloss on Rec GaN mainly comes from I-V overlap loss
09
HSW turn-off transient: current commutation
t7~t8,current commutation:
Load current gradually commutates from Rec GaN to Syn GaN, as Vgsdecreases;
Duringcurrent commutation, the gate driver discharges Ciss until Rec GaN has been turned off(Vgs= Vth)
WhenRec GaN Vgs= Vth (i.e. after t8), all the inductive-load current flows through theSyn GaN.
Powerloss mainly comes from I-V overlap loss
Part 3 : Summary
01
Summary
更多关于 GaN 器件在系统中的损耗,我们将以 200V→400V 同步 boost 48V→12V同步 buck 来进行实例说明,敬请期待。
  • 半导体
  • 功率器件
  • GaN
    GaN
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    (开关电源EMI设计)Integrated EMI/Thermal Design for Switching Power Supplies
    ;>Integrated EMI/Thermal Design for Switching Power Supplies<br/><
    发表于 07-13 11:33
    switching power supply (SMPS)开关频率
    switching power supply 开关频率选择现在通常在switching power supply(SMPS)设计中用到了“软开关”,和/或,“低功耗/无损缓冲器“。现在,对于一个
    发表于 04-08 00:43
    undefined behavior
    当我在程序里写这一句:Push_Key = (P1IFG&(~P1DIR));要读出哪一个按键被按下时,会有提醒undefined behavior: the order of volatile accesses is undefined in this statement,求大神解答。
    发表于 08-08 19:00
    源代码在STM8S003F3P6微控制器中损坏
    你好 我用STM8S003F3P6微控制器开发了一个定时器和频率计。连接LCD以显示频率和时间。并且还读取远程开关(PLC实际开关),相应地控制(切换)发电机的外部驱动板。但是在几个开关循环之后
    发表于 12-28 16:07
    A finite element analysis of f
    A finite element analysis of frequency–temperature relations of AT-cut quartz crystal resonators
    发表于 11-24 16:37 8次下载
    Analysis of dv/dt Induced Spur
    Analysis of dv/dt Induced Spurious Turn-on of MOSFET:Power MOSFET is the key semiconductor
    发表于 11-26 11:17 10次下载
    Circuit Analysis II with MATLA
    Circuit Analysis II with MATLAB :This text is written for use in a second course in circuit
    发表于 02-10 11:25 0次下载
    Circuit <b class='flag-5'>Analysis</b> II with MATLA
    Effects of High Switching Freq
    Effects of High Switching Frequency on Buck Regulators The switching frequency is an operating
    发表于 04-16 16:06 22次下载
    Monitoring and Analysis-PQ Aud
    Monitoring and Analysis-PQ Audit,the first step towards PQ mitigation Agenda• Condition
    发表于 05-17 16:56 15次下载
    什么是CS (Circuit Switching)
    什么是CS (Circuit Switching)  英文缩写: CS (Circuit Switching) 中文译名: 电路交换 分  类: 网络与交换 解  释
    发表于 02-22 17:29 8493次阅读
    Stability Analysis of Current Fe
    Stability Analysis of Current Feedback Amplifiers
    发表于 03-24 11:32 1次下载
    Optimization of Extraction Technology and Property Analysis of CORTEX
    发表于 09-28 09:56 5次下载
    Optimization of Extraction Technology and Property <b class='flag-5'>Analysis</b> of CORTEX
    应用指导 | CGAN002: How to read GaN datasheet
    云镓半导体应用指导CGAN002:HowtoreadGaNdatasheet1.命名规则以CG65030TAD产品为例,"C"为公司名CloudSemi,"G"
    的头像 发表于 11-11 11:46 794次阅读
    应用<b class='flag-5'>指导</b> | <b class='flag-5'>CGAN</b>002: How to read <b class='flag-5'>GaN</b> datasheet
    应用指导 | CGAN005: GaN FET SPICE model simulation
    云镓半导体应用指导CGAN005:GaNFETSPICEmodel&simulation1.前言众所周知,GaN功率器件具有传统功率器件无可比拟的性能优势,如大幅提升的开关速度和显著降低
    的头像 发表于 11-11 13:44 595次阅读
    应用<b class='flag-5'>指导</b> | <b class='flag-5'>CGAN</b>005: <b class='flag-5'>GaN</b> FET SPICE model  simulation
    应用指导 | CGAN004: GaN FET loss calculation (Boost converter)
    云镓半导体应用指导CGAN004:GaNFETlosscalculation(Boostconverter)众所周知,GaN功率器件具有传统功率器件无可比拟的性能优势,如大幅提升的开关速度和显著降低
    的头像 发表于 11-11 13:44 401次阅读
    应用<b class='flag-5'>指导</b> | <b class='flag-5'>CGAN</b>004: <b class='flag-5'>GaN</b> FET loss calculation (Boost converter)
