瑞萨电子 RZ MPUs 产品组合概览表
| 应用领域 | 产品型号 | 处理器核心架构与频率 | 主要特性 | 支持操作系统 |
| Vision AI | RZ/V2M | 1.0GHz Dual-core Cortex-A55 | DRP-AI (576-MAC), OpenCV Accelerator | Linux/Android™/RTOS |
| RZ/V2H | 1.8GHz Quad-core Cortex-A55 | DRP-AI3 (4K-MAC), 4K-ISP, 3D-GPU | ||
| RZ/V2L | 1.2GHz Dual-core Cortex-A55 | DRP-AI (576-MAC), 3D-GPU | ||
| Industrial Network | RZ/N1D | 500MHz Dual-core Cortex-A7 + 125MHz Cortex-M3 | Industrial Ethernet | RTOS |
| RZ/N1S | 500MHz Cortex-A7 + 125MHz Cortex-M3 | Industrial Ethernet | ||
| RZ/N1L | 125MHz Cortex-M3 | Industrial Ethernet | ||
| Real-time Control | RZ/T1 | 600MHz Cortex-R4 + 150MHz Cortex-M3 | 1-axis motor control, Industrial Ethernet | |
| RZ/T2M | 800MHz Dual-core Cortex-R52 | 2-axis motor control, Industrial Ethernet | ||
| RZ/T2L | 800MHz Cortex-R52 | 2-axis motor control, EtherCAT | ||
| IoT Edge | RZ/G3S | 1.1GHz Cortex-A55 + 250MHz Dual Cortex-M3 | LPDDR4/DDR4 | Linux/Android™/RTOS |
| RZ/Five | 1.0GHz RISC-V (AX45MP) | DDR4/3L, GbE Ethernet, CAN-FD | ||
| HMI | RZ/G2H | 1.5GHz Quad A57 + Cortex-A53 | LPDDR4, 3D-GPU, H.264/5 | |
| RZ/G2M | 1.5GHz Dual A57 + Cortex-A53 | LPDDR4, 3D-GPU, H.264/5 | ||
| RZ/G2E | 1.2GHz Dual-core Cortex-A53 | DDR3, 3D-GPU, H.264/5 | ||
| RZ/G2L | 1.2GHz Dual-core Cortex-A55 | DDR4/3L, 3D-GPU, H.264, CAN-FD | ||
| RZ/G2LC | 1.2GHz Dual-core Cortex-A55 | DDR4/3L, 3D-GPU, CAN-FD | ||
| RZ/G2UL | 1.0GHz Cortex-A55 | DDR4/3L, CAN-FD, ADC | ||
| RZ/A3UL | 1.0GHz Cortex-A55 | DDR4/3L, LCDC, GbE Ethernet, USB | ||
| RZ/G1H | 1.4GHz Quad A15 + Cortex-A7 | DDR3, 3D-GPU, H.264 | ||
| RZ/G1M | 1.5GHz Dual-core Cortex-A15 | DDR3, 3D-GPU, H.264 | ||
| RZ/A2M | 528MHz Cortex-A9 | 4MB RAM, MIPI-CSI, Ethernet, USB | ||
| RZ/A1H | 400MHz Cortex-A9 | 10MB RAM, JPEG, Ethernet, USB | ||
| RZ/A1L | 400MHz Cortex-A9 | 3MB RAM, Ethernet, USB | ||
| RZ/A1LU | 400MHz Cortex-A9 | 3MB RAM, JPEG, Ethernet, USB |
注:
此表格已按应用领域横向分类整理,保留原图关键参数并优化可读性,工程师可快速对比型号差异定位需求方案。
举报投诉
瑞萨
38文章
22518浏览量
91182 -
微处理器
11文章
2440浏览量
86143
热点推荐
RZ/G2L与RZ/G2LC系列MPU深度解析:硬件设计开发的新选择
RZ/G2L与RZ/G2LC系列MPU深度解析:硬件设计开发的新选择 在电子工程师的日常工作中,选择合适的微处理器单元(MPU)对于项目的成功至关重要。今天,我们就来深入探讨一下
HMI应用新选择:基于瑞萨RZ/A3M的LVGL Demo Setup教程(下)
RA生态工作室关注我们前期回顾01HMI应用新选择:基于瑞萨RZ/A3M的LVGLDemoSetup教程(上)接下来介绍瑞萨
瑞萨RZ/G2L微处理器Linux内核中热管理框架介绍
RZ/G2L微处理器配备Cortex-A55(1.2 GHz)CPU、16位DDR3L/DDR4接口、带Arm Mali-G31的3D图形加速引擎以及视频编解码器(H.264)。此外,这款微处
盟通科技基于瑞萨RZ MPU的EtherCAT主站应用方案
瑞萨电子携手盟通科技推出基于瑞萨RZ MPU的EtherCAT主站应用方案,为工业机器人、伺服驱动、PLC和自动化控制设备等应用场景提供完整
基于瑞萨RZ/G2L微处理器的eMMC双阶段混合烧录方案
RZ/G2L微处理器配备Cortex-A55(1.2GHz)CPU、16位DDR3L/DDR4接口、带Arm Mali-G31的3D图形加速引擎以及视频编解码器(H.264)。此外,这款微处理
基于瑞萨RZ/G2L微处理器的Ubuntu系统移植指南
瑞萨电子打造高级BLE、Wi-Fi和NFC解决方案
瑞萨提供行业领先的无线通信解决方案,包括超高效 Wi-Fi,功能丰富的蓝牙 低功耗 SoC 和具有卓越的灵敏度和输出功率的 NFC。瑞萨无线技术与先进的嵌入式
IoT Edge MPU# RZ/G3S微处理器 数据手册和产品介绍
瑞萨电子(Renesas Electronics)出品的 RZ/G3S微处理器具有三个Arm® Cortex® 内核(1个A55和2个M33)、一个16位LPDDR4/DDR4接口,支
RZ/A3M 1 GHz微处理器(MPU)数据手册和产品介绍
Renesas Electronics RZ/A3M 1GHz微处理器基于Arm^®^ Cortex ^®^ -A55 (CA55) 内核(带NEON™扩展)。内置大容量128MB DDR3L存储器
瑞萨MCU方案:瑞萨RZ/G2L Bootloader单独编译方法详解
RZ/G2L微处理器配备Cortex -A55(1.2 GHz)CPU、16位DDR3L/DDR4接口、带Arm Mali-G31的3D图形加速引擎以及视频编解码器(H.264)。此外,这款
瑞萨RZ/G2UL微处理器引脚复用分析方法
RZ/G2UL微处理器配备Cortex-A55(1.0 GHz)CPU、16位DDR3L/DDR4接口以及简单的LCD控制器。此外,这款微处理器还配备有大量接口,如摄像头输入、显示输出
新品发布丨瑞萨电子推出RZ/A3M,面向经济型高性能HMI解决方案扩展RZ/A MPU产品线
基于RTOS的RZ/A系列推出一款全新高性能微处理器(MPU)——RZ/A3M,以满足对高阶人机界面(HMI)系统日益增长的需求。全新RZ/
瑞萨 RZ 系列微处理器产品组合盘点
