环境查看
系统环境
# lsb_release -a No LSB modules are available. Distributor ID:Ubuntu Description:Ubuntu 22.04.4 LTS Release:22.04 Codename:jammy # cat /etc/redhat-release Rocky Linux release 9.3 (Blue Onyx)
软件环境
# kubectl version Client Version: v1.30.2 Kustomize Version: v5.0.4-0.20230601165947-6ce0bf390ce3 Server Version: v1.25.16 WARNING: version difference between client (1.30) and server (1.25) exceeds the supported minor version skew of +/-1
安装Nvidia的Docker插件
在有GPU资源的主机安装,改主机作为K8S集群的Node
设置源
# curl -fsSL https://nvidia.github.io/libnvidia-container/gpgkey | sudo gpg --dearmor -o /usr/share/keyrings/nvidia-container-toolkit-keyring.gpg && curl -s -L https://nvidia.github.io/libnvidia-container/stable/deb/nvidia-container-toolkit.list | sed 's#deb https://#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://#g' | sudo tee /etc/apt/sources.list.d/nvidia-container-toolkit.list
配置存储库以使用实验性软件包
# sed -i -e '/experimental/ s/^#//g' /etc/apt/sources.list.d/nvidia-container-toolkit.list
修改后把以下注释取消
更新
# sudo apt-get update
安装Toolkit
# sudo apt-get install -y nvidia-container-toolkit
配置Docker以使用Nvidia
# sudo nvidia-ctk runtime configure --runtime=docker INFO[0000] Loading config from /etc/docker/daemon.json INFO[0000] Wrote updated config to /etc/docker/daemon.json INFO[0000] It is recommended that docker daemon be restarted.
这条命令会修改配置文件/etc/docker/daemon.json添加runtimes配置
# cat /etc/docker/daemon.json
"insecure-registries": [
"192.168.3.61"
"registry-mirrors": [
"https://7sl94zzz.mirror.aliyuncs.com",
"https://hub.atomgit.com",
"https://docker.awsl9527.cn"
"runtimes": {
"nvidia": {
"args": [],
"path": "nvidia-container-runtime"
重启docker
# systemctl daemon-reload # systemctl restart docker
使用Docker调用GPU
验证配置
启动一个镜像查看GPU信息
~# docker run --rm --runtime=nvidia --gpus all ubuntu nvidia-smi Sat Oct 12 01:33:33 2024 +-----------------------------------------------------------------------------------------+ | NVIDIA-SMI 555.42.06 Driver Version: 555.42.06 CUDA Version: 12.5 | |-----------------------------------------+------------------------+----------------------+ | GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |=========================================+========================+======================| | 0 NVIDIA GeForce RTX 4090 Off | 00000000:01:00.0 Off | Off | | 0% 53C P2 59W / 450W | 4795MiB / 24564MiB | 0% Default | | | | N/A | +-----------------------------------------+------------------------+----------------------+ +-----------------------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=========================================================================================| | No running processes found | +-----------------------------------------------------------------------------------------+
该输出结果显示了 GPU 的详细信息,包括型号、温度、功率使用情况和内存使用情况等。这表明 Docker 容器成功地访问到了 NVIDIA GPU,并且 NVIDIA Container Toolkit 安装和配置成功。
4. 使用K8S集群Pod调用GPU
以下操作在K8S机器的Master节点操作
安装K8S插件
下载最新版本
$ kubectl create -f https://raw.githubusercontent.com/NVIDIA/k8s-device-plugin/v0.16.1/deployments/static/nvidia-device-plugin.yml
yml文件内容如下
# cat nvidia-device-plugin.yml apiVersion: apps/v1 kind: DaemonSet metadata: name: nvidia-device-plugin-daemonset namespace: kube-system spec: selector: matchLabels: name: nvidia-device-plugin-ds updateStrategy: type: RollingUpdate template: metadata: labels: name: nvidia-device-plugin-ds spec: tolerations: - key: nvidia.com/gpu operator: Exists effect: NoSchedule # Mark this pod as a critical add-on; when enabled, the critical add-on # scheduler reserves resources for critical add-on pods so that they can # be rescheduled after a failure. # See https://kubernetes.io/docs/tasks/administer-cluster/guaranteed-scheduling-critical-addon-pods/ priorityClassName: "system-node-critical" containers: - image: nvcr.io/nvidia/k8s-device-plugin:v0.16.1 name: nvidia-device-plugin-ctr env: - name: FAIL_ON_INIT_ERROR value: "false" securityContext: allowPrivilegeEscalation: false capabilities: drop: ["ALL"] volumeMounts: - name: device-plugin mountPath: /var/lib/kubelet/device-plugins volumes: - name: device-plugin hostPath: path: /var/lib/kubelet/device-plugins
使用DaemonSet方式部署在每一台node服务器部署
查看Pod日志
# kubectl logs -f nvidia-device-plugin-daemonset-8bltf -n kube-system I1012 02:15:37.171056 1 main.go:199] Starting FS watcher. I1012 02:15:37.171239 1 main.go:206] Starting OS watcher. I1012 02:15:37.172177 1 main.go:221] Starting Plugins. I1012 02:15:37.172236 1 main.go:278] Loading configuration. I1012 02:15:37.173224 1 main.go:303] Updating config with default resource matching patterns. I1012 02:15:37.173717 1 main.go:314] Running with config: { "version": "v1", "flags": { "migStrategy": "none", "failOnInitError": false, "mpsRoot": "", "nvidiaDriverRoot": "/", "nvidiaDevRoot": "/", "gdsEnabled": false, "mofedEnabled": false, "useNodeFeatureAPI": null, "deviceDiscoveryStrategy": "auto", "plugin": { "passDeviceSpecs": false, "deviceListStrategy": [ "envvar" ], "deviceIDStrategy": "uuid", "cdiAnnotationPrefix": "cdi.k8s.io/", "nvidiaCTKPath": "/usr/bin/nvidia-ctk", "containerDriverRoot": "/driver-root" } }, "resources": { "gpus": [ { "pattern": "*", "name": "nvidia.com/gpu" } ] }, "sharing": { "timeSlicing": {} } } I1012 02:15:37.173760 1 main.go:317] Retrieving plugins. E1012 02:15:37.174052 1 factory.go:87] Incompatible strategy detected auto E1012 02:15:37.174086 1 factory.go:88] If this is a GPU node, did you configure the NVIDIA Container Toolkit? E1012 02:15:37.174096 1 factory.go:89] You can check the prerequisites at: https://github.com/NVIDIA/k8s-device-plugin#prerequisites E1012 02:15:37.174104 1 factory.go:90] You can learn how to set the runtime at: https://github.com/NVIDIA/k8s-device-plugin#quick-start E1012 02:15:37.174113 1 factory.go:91] If this is not a GPU node, you should set up a toleration or nodeSelector to only deploy this plugin on GPU nodes I1012 02:15:37.174123 1 main.go:346] No devices found. Waiting indefinitely.
驱动失败,错误提示已经清楚说明了失败原因
该Node部署GPU节点即该Node没有GPU资源
该Node有GPU资源,没有安装Docker驱动
没有GPU资源的节点肯定无法使用,但是已经有GPU资源的Node节点也会报这个错误
有GPU节点的修复方法,修改配置文件添加配置
"192.168.3.61"
"default-runtime": "nvidia",
"runtimes": {
"nvidia": {
"args": [],
"path": "/usr/bin/nvidia-container-runtime"
关键配置是以下行
再次查看Pod日志
# kubectl logs -f nvidia-device-plugin-daemonset-mp5ql -n kube-system
I1012 02:22:00.990246 1 main.go:199] Starting FS watcher.
I1012 02:22:00.990278 1 main.go:206] Starting OS watcher.
I1012 02:22:00.990373 1 main.go:221] Starting Plugins.
I1012 02:22:00.990382 1 main.go:278] Loading configuration.
I1012 02:22:00.990692 1 main.go:303] Updating config with default resource matching patterns.
I1012 02:22:00.990776 1 main.go:314]
"version": "v1",
"flags": {
"mpsRoot": "",
"plugin": {
"envvar"
"resources": {
"gpus": [
"pattern": "*",
"sharing": {
"timeSlicing": {}
I1012 02:22:00.990780 1 main.go:317] Retrieving plugins.
I1012 02:22:01.010950 1 server.go:216] Starting GRPC server for 'nvidia.com/gpu'
I1012 02:22:01.011281 1 server.go:147] Starting to serve 'nvidia.com/gpu' on /var/lib/kubelet/device-plugins/nvidia-gpu.sock
I1012 02:22:01.012376 1 server.go:154] Registered device plugin for 'nvidia.com/gpu' with Kubelet
查看GPU节点信息
# kubectl describe node aiserver003087
在k8s中测试GPU资源调用
测试Pod
# cat gpu_test.yaml
apiVersion: v1
kind: Pod
metadata:
spec:
nodeName: aiserver003087 #指定有gpu的节点
containers:
- name: ffmpeg-container
image: nightseas/ffmpeg:latest #k8s中配置阿里的私有仓库遇到一些问题,暂时用公共镜像
command: [ "/bin/bash", "-ce", "tail -f /dev/null" ]
resources:
limits:
nvidia.com/gpu: 1 # 请求分配 1个 GPU
创建Pod
# kubectl apply -f gpu_test.yaml pod/ffmpeg-pod configured
往Pod内倒入一个视频进行转换测试
# kubectl cp test.mp4 ffmpeg-pod:/root
进入Pod
# kubectl exec -it ffmpeg-pod bash
转换测试视频
# ffmpeg -hwaccel cuvid -c:v h264_cuvid -i test.mp4 -vf scale_npp=1280:720 -vcodec h264_nvenc out.mp4
成功转换并且输出out.mp4则代表调用GPU资源成功
为保证DaemonSet至部署至带GPU资源的服务器可以做一个node标签选择器
设置给节点标签
# kubectl label nodes aiserver003087 gpu=true
修改DaemonSet配置文件添加标签选择保证DaemonSet至部署至带gpu=true标签的Node上
deployment配置文件修改位置是一致的
修改gpu测试Pod的yaml文件使用标签选择器
# cat gpu_test.yaml
apiVersion: v1
kind: Pod
metadata:
spec:
#nodeName: aiserver003087 #指定有gpu的节点
containers:
resources:
limits:
nvidia.com/gpu: 1
nodeSelector:
gpu: "true"
#kubernetes.io/os: linux
注意: 标签选择器需要值需要添加双引号"true"否则apply会报错,不能把bool值作为对应的值应用至标签选择器
K8S集群会自动调用GPU资源,但是如果一个GPU设备已经被使用,再启动一个应用时可能调用到改设备导致显存溢出
可以修改配置指定GPU设备启动
指定第8块显卡启动应用,设备号从0开始计算
链接:https://www.cnblogs.com/minseo/p/18460107
gpu
28文章
5110浏览量
134511 -
集群
130浏览量
17603 -
命令
5文章
746浏览量
23459 -
Docker
526浏览量
14046
原文标题:AI时代GPU加速:如何通过Docker和K8S集群实现高效调用GPU
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
什么是 K8S,如何使用 K8S
全面提升,阿里云Docker/Kubernetes(K8S) 日志解决方案与选型对比
K8s 从懵圈到熟练 – 集群网络详解
k8s容器运行时演进历史
Docker不香吗为什么还要用K8s
简单说明k8s和Docker之间的关系
K8S集群服务访问失败怎么办 K8S故障处理集锦
k8s是什么意思?kubeadm部署k8s集群(k8s部署)|PetaExpres
K8s多集群管理:为什么需要多集群、多集群的优势是什么
k8s云原生开发要求
