自建K8S集群认证过期
马哥Linux运维 来源:博客园 2025-02-07 12:32 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
今天使用kubectl命令查看pod信息时,一直正常运行的k8s集群突然不能访问了,输入任何命令都提示以下报错:
Unable to connect to the server: x509: certificate has expired or is not yet valid: current time 2025-01-25T1145+08:00 is after 2024-11-22T2348Z
解决方案:
参考官方文档:kubeadm证书管理使用命令kubeadm alpha certs来管理证书:
使用命令kubeadm alpha certs renew all更新证书,返回
[renew] Reading configuration from the cluster...
[renew] FYI: You can look at this config file with 'kubectl -n kube-system get cm kubeadm-config -oyaml'
certificate embedded in the kubeconfig file for the admin to use and for kubeadm itself renewed
certificate for serving the Kubernetes API renewed
certificate the apiserver uses to access etcd renewed
certificate for the API server to connect to kubelet renewed
certificate embedded in the kubeconfig file for the controller manager to use renewed
certificate for liveness probes to healthcheck etcd renewed
certificate for etcd nodes to communicate with each other renewed
certificate for serving etcd renewed
certificate for the front proxy client renewed
certificate embedded in the kubeconfig file for the scheduler manager to use renewed
使用如下命令拷贝新生成的配置文件
sudo kubeadm alpha kubeconfig user --client-name=admin --org=system:masters > /tmp/admin.conf
sudo cp /tmp/admin.conf $HOME/.kube/config
sudo chown $(id -u):$(id -g) $HOME/.kube/config
重启kubeletsystemctl restart kubelet即可正常使用K8S集群
[root@k8smaster k8s]# kubectl get po
NAME READY STATUS RESTARTS AGE
cron-job-test-1732318920-k2g76 0/1 Completed 0 63d
cron-job-test-1732318980-kcr4x 0/1 Completed 0 63d
cron-job-test-1732319040-b88rf 0/1 Completed 0 63d
再次查看证书到期情况
[root@k8smaster k8s]# kubeadm alpha certs check-expiration
[check-expiration] Reading configuration from the cluster...
[check-expiration] FYI: You can look at this config file with 'kubectl -n kube-system get cm kubeadm-config -oyaml'
CERTIFICATE EXPIRES RESIDUAL TIME CERTIFICATE AUTHORITY EXTERNALLY MANAGED
admin.conf Jan 25, 2026 05:55 UTC 364d no
apiserver Jan 25, 2026 05:55 UTC 364d ca no
apiserver-etcd-client Jan 25, 2026 05:55 UTC 364d etcd-ca no
apiserver-kubelet-client Jan 25, 2026 05:55 UTC 364d ca no
controller-manager.conf Jan 25, 2026 05:55 UTC 364d no
etcd-healthcheck-client Jan 25, 2026 05:55 UTC 364d etcd-ca no
etcd-peer Jan 25, 2026 05:55 UTC 364d etcd-ca no
etcd-server Jan 25, 2026 05:55 UTC 364d etcd-ca no
front-proxy-client Jan 25, 2026 05:55 UTC 364d front-proxy-ca no
scheduler.conf Jan 25, 2026 05:55 UTC 364d no
CERTIFICATE AUTHORITY EXPIRES RESIDUAL TIME EXTERNALLY MANAGED
ca Nov 20, 2033 23:44 UTC 8y no
etcd-ca Nov 20, 2033 23:44 UTC 8y no
front-proxy-ca Nov 20, 2033 23:44 UTC 8y no
注意事项:
官网上给的命令是kubeadm certs check-expiration,标识的k8s版本是V1.15,直接在本地执行该命令报错:
[root@k8smaster k8s]# kubeadm certs check-expiration
unknown command "certs" for "kubeadm"
To see the stack trace of this error execute with --v=5 or higher
查了下,我本地的k8s版本是1.19,certs命令放在了kubeadm alpha下,需要将kubeadm certs替换为kubeadm aplha certs执行即可
[root@k8smaster k8sh]# kubeadm version
kubeadm version: &version.Info{Major:"1", Minor:"19", GitVersion:"v1.19.5", GitCommit:"e338cf2c6d297aa603b50ad3a301f761b4173aa6", GitTreeState:"clean", BuildDate:"2020-12-09T1140Z", GoVersion:"go1.15.2", Compiler:"gc", Platform:"linux/amd64"}
[root@k8smaster k8s]# kubeadm --help
│ KUBEADM │
│ Easily bootstrap a secure Kubernetes cluster │
│ Please give us feedback at: │
│ https://github.com/kubernetes/kubeadm/issues │
Example usage:
Create a two-machine cluster with one control-plane node
(which controls the cluster), and one worker node
(where your workloads, like Pods and Deployments run).
│ On the first machine: │
│ control-plane# kubeadm init │
│ On the second machine: │
│ worker# kubeadm join
You can then repeat the second step on as many other machines as you like.
Usage:
kubeadm [command]
Available Commands:
alpha Kubeadm experimental sub-commands
completion Output shell completion code for the specified shell (bash or zsh)
config Manage configuration for a kubeadm cluster persisted in a ConfigMap in the cluster
help Help about any command
init Run this command in order to set up the Kubernetes control plane
join Run this on any machine you wish to join an existing cluster
reset Performs a best effort revert of changes made to this host by 'kubeadm init ' or 'kubeadm join'
token Manage bootstrap tokens
upgrade Upgrade your cluster smoothly to a newer version with this command
version Print the version of kubeadm
Flags:
--add-dir-header If true, adds the file directory to the header of the lo g messages
-h, --help help for kubeadm
--log-file string If non-empty, use this log file
--log-file-max-size uint Defines the maximum size a log file can grow to. Unit is megabytes. If the value is 0, the maximum file size is unlimited. (default 1800)
--rootfs string [EXPERIMENTAL] The path to the 'real' host root filesyst em.
--skip-headers If true, avoid header prefixes in the log messages
--skip-log-headers If true, avoid headers when opening log files
-v, --v Level number for the log level verbosity
Use "kubeadm [command] --help" for more information about a command.
[root@k8smaster k8s]# kubectl alpha --help
These commands correspond to alpha features that are not enabled in Kubernetes
clusters by default.
Available Commands:
debug Attach a debug container to a running pod
Use "kubectl --help" for more information about a given command.
[root@k8smaster k8s]# kubeadm alpha --help
Usage:
kubeadm alpha [command]
Available Commands:
certs Commands related to handling kubernetes certificates
kubeconfig Kubeconfig file utilities
selfhosting Make a kubeadm cluster self-hosted
Flags:
-h, --help help for alpha
Global Flags:
--add-dir-header If true, adds the file directory to the header of the log messages
--rootfs string [EXPERIMENTAL] The path to the 'real' host root filesystem.
Additional help topics:
kubeadm alpha phase Invoke subsets of kubeadm functions separately for a manual install
Use "kubeadm alpha [command] --help" for more information about a command.
链接:https://www.cnblogs.com/wenha/p/18690938
  • 集群
  • 命令
原文标题:自建K8S集群认证过期
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    什么是 K8S,如何使用 K8S
    连续性。 适用场景: 大规模容器集群管理。 微服务架构的部署与运维。 需要弹性伸缩的在线服务。 多租户环境(如开发测试、生产环境隔离)。 总的来说,K8S 通过标准化容器管理,极大降低了分布式系统的运维复杂度,是云原生时代的核心基础设施。
    发表于 06-25 06:45
    K8s 从懵圈到熟练 – 集群网络详解
    导读:阿里云 K8S 集群网络目前有两种方案:一种是 flannel 方案;另外一种是基于 calico 和弹性网卡 eni 的 terway 方案。Terway 和 flannel 类似
    发表于 10-14 15:06
    搭建K8s环境平台的步骤
    1 搭建K8s环境平台规划1.1 单master集群1.2 多master集群
    发表于 11-04 06:03
    Docker不香吗为什么还要用K8s
    Docker 虽好用,但面对强大的集群,成千上万的容器,突然感觉不香了。 这时候就需要我们的主角 Kubernetes 上场了,先来了解一下 K8s 的基本概念,后面再介绍实践,由浅入深步步为营
    的头像 发表于 06-02 11:56 3944次阅读
    简单说明k8s和Docker之间的关系
    这篇文章主要介绍了k8s和Docker关系简单说明,本文利用图文讲解的很透彻,有需要的同学可以研究下 最近项目用到kubernetes(以下简称k8sks之间有
    的头像 发表于 06-24 15:48 4004次阅读
    K8S集群服务访问失败怎么办 K8S故障处理集锦
    问题1:K8S集群服务访问失败?     原因分析:证书不能被识别,其原因为:自定义证书,过期等。 解决方法:更新证书即可。 问题2:K8S集群
    的头像 发表于 09-01 11:11 1.7w次阅读
    <b class='flag-5'>K8S</b><b class='flag-5'>集群</b>服务访问失败怎么办 <b class='flag-5'>K8S</b>故障处理集锦
    k8s集群环境中工作有多快
    命令就会很低效。 今天介绍3个工具会让你在多k8s集群环境中工作的很轻松。我将从以下几个方面来评估工具实用性: 速度 如果你有多个k8s集群可选择,你切换
    的头像 发表于 05-29 14:28 996次阅读
    多<b class='flag-5'>k8s</b><b class='flag-5'>集群</b>环境中工作有多快
    切换k8s上下文有多快
    use-context 命令就会很低效。 今天介绍3个工具会让你在多k8s集群环境中工作的很轻松。我将从以下几个方面来评估工具实用性: 速度 如果你有多个k8s集群可选择,你切换
    的头像 发表于 05-29 15:26 1230次阅读
    切换<b class='flag-5'>k8s</b>上下文有多快
    k8s是什么意思?kubeadm部署k8s集群k8s部署)|PetaExpres
    k8s是什么意思? kubernetes简称K8s,是一个开源的,用于管理云平台中多个主机上的容器化的应用,Kubernetes的目标是让部署容器化的应用简单并且高效(powerful
    发表于 07-19 13:14 1555次阅读
    K8s集群管理:为什么需要多集群、多集群的优势是什么
    随着K8s和云原生技术的快速发展,以及各大厂商在自己的数据中心使用K8s的API进行容器化应用编排和管理,让应用交付本身变得越来越标准化和统一化,并且实现了与底层基础设施的完全解耦,为多集群和混合云提供了一个坚实技术基础。
    发表于 09-14 10:48 2456次阅读
    <b class='flag-5'>K8s</b>多<b class='flag-5'>集群</b>管理:为什么需要多<b class='flag-5'>集群</b>、多<b class='flag-5'>集群</b>的优势是什么
    纳尼?自建K8s集群日志收集还能通过JMQ保存到JES
    作者:京东科技 刘恩浩 一、背景 基于K8s集群的私有化交付方案中,日志收集采用了ilogtail+logstash+kafka+es方案,其中ilogtail负责日志收集,logstash负责对数
    的头像 发表于 09-30 14:45 692次阅读
    混合云部署k8s集群方法有哪些?
    混合云部署k8s集群方法是首先需在本地与公有云分别建立K8s集群,并确保网络连接。接着,配置kubeconfig文件连接两集群,并安装云服务
    的头像 发表于 11-07 09:37 761次阅读
    如何通过Docker和K8S集群实现高效调用GPU
    在有GPU资源的主机安装,改主机作为K8S集群的Node。
    的头像 发表于 03-18 16:50 929次阅读
    如何通过Docker和<b class='flag-5'>K8S</b><b class='flag-5'>集群</b>实现高效调用GPU
    解析K8S实用命令
    前言: 作为运维工程师,掌握 Kubernetes 命令行工具是日常工作的核心技能。本文将深入解析 K8S 最实用的命令,从基础操作到高级技巧,助你成为容器化集群管理专家。
    的头像 发表于 07-24 14:07 531次阅读
    K8s集群性能调优实战技巧
    大多数团队在遇到K8s性能问题时,第一反应是"加机器"。但根据我对超过50个生产集群的分析,80%的性能问题源于配置不当,而非资源不足。
    的头像 发表于 09-08 09:36 483次阅读
