史蒂夫.乔布斯说,”复杂的终极境界是简单“,同样的优雅的代码一定是精简明了,可读性好。
使用LocalDate和LocalDateTime
LocalDate精确到日期,LocalDateTime精确到时分秒。优化前14行代码
try { -
SimpleDateFormat sdfDay = new SimpleDateFormat("yyyy-MM-dd"); -
SimpleDateFormat sdfMins = new SimpleDateFormat("yyyy-MM-dd HHss"); -
Date now = new Date(); -
String today = sdfDay.format(now); -
String waterStart = today + " 0300"; -
String waterEnd = today + " 0400"; -
Date waterStartTime = sdfMins.parse(waterStart); -
Date waterEndTime = sdfMins.parse(waterEnd); -
} catch (ParseException pe) { -
return XX; -
优化后3行代码
LocalDateTime now = LocalDateTime.now(); -
LocalDateTime waterStart = LocalDateTime.of(now.getYear(), now.getMonth(),now.getDayOfMonth(),3,0); -
LocalDateTime waterEndTime =LocalDateTime.of(now.getYear(), now.getMonth(),now.getDayOfMonth(),4,0);
默认值使用Optional
优化前五行
if (null == status) { -
param.put("status", new ArrayList<String>()); -
} else { -
param.put("status", status); -
优化后一行,使用JDK8的Optional
Optional.ofNullable(status).orElse(new ArrayList<String>());
如果是字符串可以用
StringUtils.defaultIfEmpty(status,"")
字符串累加
字符串只要不在for循环里累加,可以直接用+号,因为编译成字节码后会变成StringBuilder,如果在for循环里面用+号会生成多个StringBuilder,所以在for循环里累加最好在循环外创建StringBuilder。优化前五行
StringBuffer sblog = new StringBuffer(); -
sblog.append("waterDriven|sellerId="); -
sblog.append(request.getSellerTaobaoId()); -
sblog.append("|result="); -
sblog.append(isSuccess);
优化后一行
String sblog="waterDriven|sellerId="+request.getSellerTaobaoId()+"|result="+isSuccess;
以上场景用逗号和等号连接数据,使用GUAVA的Joiner更精简,可读性更好
String sblog=Joiner.on("|").withKeyValueSeparator("=").join(ImmutableMap.of("sellerId", request.getSellerTaobaoId(), "result", isSuccess))
LIST TO MAP
优化前4行
for (AssetsInfoBO assetsInfoBO : request.getAssetsCollectionList()) { -
AssetsMetaIdMap.put(assetsInfoBO.getAssetMetadataId(), assetsInfoBO.getAssetMetadataId()); -
优化后1行
Map<String, String> AssetsMetaIdMap = request.getAssetsCollectionList().stream().collect(Collectors.toMap(Hosting::getAssetMetadataId, Hosting::getAssetMetadataId));
如果key重复会抛出异常
Exception in thread "main" java.lang.IllegalStateException: Duplicate key 80000
减少不需要的判断
优化前5行
String requestId = null; -
if (null != request.getExtData()) { -
requestId = request.getExtDataValue(REQUEST_ID_KEY); -
return requestId;
优化后1行
return request.getExtDataValue(REQUEST_ID_KEY);
去掉else
优化前5行
if (null != result && StringUtils.isNotBlank(no)) { -
return no; -
} else { -
throw new RuntimeException("XX"); -
优化后4行
return no; -
不要返回布尔
优化前5行
if ("true".equalsIgnoreCase(value.toString())) { -
invoke = true; -
} else { -
invoke = false; -
优化后一行
invoke = "true".equalsIgnoreCase(value.toString());
使用级联
优化前5行
ParamBO paramBO = new ParamBO(); -
paramBO.setId(1); -
paramBO.setName(”ifeve“); -
paramBO.setOld(7);
优化后1行
new ParamBO().withId(1).withName("ifeve").withOld(7);
-End-
审核编辑 :李倩
代码
30文章
4976浏览量
74373 -
LOCA
11浏览量
7336
原文标题:几个代码瘦身优化的案例
文章出处:【微信号:AndroidPush,微信公众号:Android编程精选】欢迎添加关注!文章转载请注明出处。
华鑫微纳:以8英寸产线为引擎,驱动国产MEMS产业新纪元
波形为什么杂乱无章?SPI为什么可观不可测?
2026蓝牙亚洲大会暨展览在深启幕:定义标准,共建紧密相连的世界
德赛电池2026年一季度业绩亮眼 归母净利润7991.65万同比增长64.23%
6mA 低静态电流 + 小封装!WD1117 稳压器:便携式设备长效供电方案
大族激光市值站上千亿 高端装备龙头彰显成长韧性
告别计量盲区!ADL3000 UL认证电表为何成光储充项目“标配”?
烽火通信李明亮相第十九届中国电子信息年会
基于德州仪器TPS61088芯片设计5v升12v的直流升压电路的典型应用概述
HMC - C014 GaAs MMIC 混频器模块:16 - 32 GHz 频段的理想之选
HMC - C009 GaAs MMIC I/Q混频器模块:性能卓越的微波解决方案
详解HMC8193 I/Q混频器:性能、应用与设计要点
