Intel Celeron 1037U处理器, 1*VGA, 1*LVDS, 2*COM, 1* LAN, 1*Mini-PCIe, DC 12V供电
- 采用Intel Celeron 1037U处理器
- 提供2*COM, 8*USB, 1*百兆LAN
- 提供1*VGA, 1*LVDS, 支持双屏异显
- 提供1*Mini-PCIe, (支持mSATA)
- 采用DC 12V供电
- 薄型Mini-ITX,板身厚度≤17mm
规格
| General | |
| CPU | Intel® Celeron® 1037U CPU, Dual-core,1.8GHz, TDP 17W |
| Chipset | Intel® NM70 Chipset, TDP 4.1W |
| Memory | Up to 8 GB DDR3 1600/1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0, 1*SATA 2.0, 1*mSATA |
| Expansion Interface | 1*Mini-PCIe (1*mSATA Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows XP/7/8/10, Linux |
| I/O Interface | |
| Serial Port | 2*RS232 |
| USB | 8*USB 2.0 (4*on rear I/O, 4*header) |
| Ethernet | 1*Realtek® PCI-E LAN for 100Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | 1*PS/2 (Keyboard and Mouse Supported) |
| Parallel Port | 1* LPT |
| GPIO | 8 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 2048*1536@75Hz |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | Mini-ITX, 170*170mm |
| Power Input | DC 12V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3716浏览量
94543 -
嵌入式主板
7文章
6107浏览量
37253 -
信步科技
7文章
264浏览量
7986
热点推荐
信步科技SV1a-302AN规格英文版
ntel® Celeron 1037U CPU, 1*VGA, 1*LVDS, 2*COM, 1*LAN, 1*Mini-PCIe, DC 12V Input
Intel® Ce
信步科技SV1-H8116主板规格英文版
Intel 4th Gen Core i3/i5/i7 CPU (LGA1150) with H81, 6*COM, 1*LAN, 1*PCI-E 16X, 1*Mini-PCIe
信步科技NVR SV1-1908主板规格英文版
(RS485, 4*in/2*out GPIO) Supports dual display of 1*VGA and 2*HDMI 规格 General CPU Intel Bay Trail
Intel Bay Trail J1900处理器, 9*SATA, 2*Intel千兆LAN, 1*Mini-PCIe, NVR 专用报警端子 采用Intel Bay Trail J1900处理器
信步科技SV1a-302AN主板规格英文版
