Intel Skylake-U Core i5-6200U处理器, 6*COM, 2*Intel千兆LAN, 2*Mini-PCIe, 背置CPU, 3.5寸 (146*105mm)
规格
| General | |
| CPU | Intel® Skylake-U CoreTM i5-6200U CPU, Dual-core, up to 2.80 GHz, TDP 15W |
| Chipset | Null |
| Memory | Up to 8 GB DDR3L 1600 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0, 1*mSATA |
| Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
| BIOS | AMI UEFI BIOS |
| System | Windows 7/8/10, Linux |
| I/O Interface | |
| Serial Port | 6*RS232 (up to 12*RS232 with SV-M6-CU) |
| USB | 2*USB 3.0+6*USB 2.0 (up to 12*USB withSV-M6-CU) |
| Ethernet | 2*Intel® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports |
| PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
| Parallel Port | Null |
| GPIO | 8 programmable GPIO |
| Feature Interface | 1*SVIO Connector |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200@60Hz |
| Multiple Display | Triple |
| Mechanical & Environment | |
| Dimension | 3.5'', 146*105mm |
| Power Input | DC 9-28V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
WINDOWS
4文章
3711浏览量
94450 -
嵌入式主板
7文章
6107浏览量
37206 -
信步科技
7文章
264浏览量
7978
热点推荐
信步科技SV3b-38626规格英文版
*Wifi+3G/4G)
Supports triple display of VGA, HDMI and LVDS/eDP
3.5'' (146*105mm)
规格
信步科技SV3b-62026规格英文版
Intel Skylake-U 6th Gen Core i5-6200U CPU at the solder side of M/B, with 6*COM, 2*1000 Mbps Intel
信步科技NVR SV4-B85B4主板规格英文版
Intel LGA1150 CPU with B85, 26*SATA, 3*1000 Mbps Intel LAN, 2*PCI-E, 1*Mini-PCIe, NVR Alarm port
信步科技SV3-26016-C主板规格英文版
Intel® Atom N2600 CPU, 6*COM, 1*LAN, 2*Mini-PCIe, DC 12V Input, 3.5'' (146*105mm)
信步科技SV3b-25516主板规格英文版
Intel Atom D2550 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV3b-26016-C主板规格英文版
Intel® Atom N2600 CPU at the solder side of M/B, with 6*COM, 1*LAN, 2*Mini-PCIe
信步科技SV3b-19026主板规格英文版
Intel Bay Trail J1900 CPU at the solder side of M/B, with 6*COM, 2*LAN, 2*Mini-PCIe, 3.5'' (146*105mm)
及全系列LGA1150处理器 采用Intel B85芯片组 提供6*Mini-SAS (24*SATA), 2*SATA 3.0, 3*Intel千兆LAN 提供NVR专用报警端子(RS485, 4
信步科技SV3b-62026主板规格英文版
