HMC7584 E-Band Upconverter SiP 71 - 76 GHz
数据:
优势和特点
  • Conversion Gain: 34 dB typical
  • Gain Control Range: 40 dB typical
  • Saturated Output Power (PSAT): 25 dBm typical
  • Output Third-Order Intercept (IP3): 31 dBm typical
  • Output Power for P1dB Compression: 24 dBm
  • Built-in Power Detector
  • Built-in Envelope Detector for I/Q Mismatch Correction
  • Fully Integrated In Surface Mount 50 Lead 16 mm x 14 mm Package
产品详情
The HMC7584LG is fully integrated System in Package (SiP) in phase/quadrature (I/Q) upconverter that operates between an IF input frequency range of DC to 2 GHz and an RF output frequency range of 71 GHz to 76 GHz. The device uses an image rejection mixer that is driven by a 6× LO multiplier. A variable gain amplifier followed by medium power amplifier are added to the mixer outputs to provide a small signal conversion gain of 34 dB typical. Differential I and Q mixer inputs are provided and can be driven with differential I and Q baseband waveforms for direct conversion applications. Alternatively, the inputs can be driven using an external 90° hybrid and two external 180° hybrids for single-ended applications.
Applications
  • E-Band Communication Systems
  • High Capacity Wireless Backhaul
  • Test & Measurement
方框图
技术文档
数据手册(1)
元器件购买 HMC7584 相关库存
相关阅读
