HMC7585 E-Band Upconverter SiP 81 - 86 GHz
数据:
优势和特点
  • Conversion Gain: 32 dB typical
  • Gain Control Range: 40 dB typical
  • Saturated Output Power (PSAT): 24 dBm typical
  • Output Third-Order Intercept (IP3): 30 dBm typical
  • Output Power for P1dB Compression: 23 dBm
  • Built-in Power Detector
  • Built-in Envelope Detector for I/Q Mismatch Correction
  • Fully Integrated In Surface Mount 50-Lead 16 mm x 14 mm Package
产品详情
The HMC7585LG is fully integrated System in Package (SiP) in phase/quadrature (I/Q) upconverter that operates from 81 GHz to 86 GHz. The device uses an image rejection mixer that is driven by a 6 × LO multiplier. A variable gain amplifier followed by a medium power amplifier are added to the mixer outputs to provide a small signal conversion gain of 32 dB typical. Differential I and Q mixer inputs are provided and can be driven with differential I and Q baseband waveforms for direct conversion applications. Alternatively, the inputs can be driven using an external 90° hybrid and two external 180° hybrids for single-sideband applications.
Applications
  • E-Band Communication Systems
  • High Capacity Wireless Backhaul
  • Test & Measurement
方框图
技术文档
数据手册(1)
元器件购买 HMC7585 相关库存
相关阅读
