TPS61093-Q1是一款兼具高集成度和高可靠性的1.2MHz固定频率升压转换器。该集成电路(IC)集成当有输出电流超出过载限值时,IC的隔离开关会断开,进而使输出与输入断开连接。这一断开功能可保护IC和输入电源。在关断期间,隔离开关也会使输出与输入断开连接,以便最大限度降低泄漏电流。当IC关断时,输出电容会通过内部二极管放电至低电压。其他保护特性包括逐周期1.1 A峰值过流保护(OCP),输出过压保护(OVP),热关断以及欠压闭锁(UVLO)。
IC的最低输入电压为1.6V,可通过两个碱性TPS61093-Q1采用带散热焊盘的2.5mm×2.5mm SON封装。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Switch Current Limit (Typ) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Iout (Max) (A) |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS61093-Q1 | LM2623-Q1 | LM2735-Q1 | TPS61085-Q1 | TPS61087-Q1 | TPS61175-Q1 |
| 1.6 | 1.0 | 2.7 | 2.3 | 2.5 | 2.9 |
| 6 | 14 | 5.5 | 6 | 6 | 18 |
| 1.7 | 1.24 | 3 | 2.8 | 3 | 2.9 |
| 17 | 14 | 24 | 18.5 | 18.5 | 38 |
| 1.1 | 2.25 | 2.6 | 4 | 3.8 | |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 300 | 480 | 900 | 160 | ||
| 1400 | 2000 | 1500 | 1500 | 2640 | |
| 0.9 | 0.11 | 7 | 0.07 | 0.075 | 3 |
| Enable Output Discharge | Enable | Enable | Enable Light Load Efficiency | Enable Power Good | Enable Frequency Synchronization Light Load Efficiency |
| 2 | |||||
| 93 | 90 | 89 | 90 | 93 | |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 105 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| SON | WSON | SOT-23 WSON | VSSOP | VSON | HTSSOP |
型号:TPS61093DSKR 封装:WSON10_EP
品牌:TI 描述:升压转换器类型-40℃~+85℃@(TA)1升压可调1.6V~17V 1.6V~6V 1.2MHz WSON10_2.5X2.5MM_EP DC-DC转换器ROHS
金额:¥6.06620
去购买
