数据: 具有自适应内部补偿功能的 TPS543C20 4VIN 至 16VIN、40A 可堆叠同步降压 SWIFT™ 转换器 数据表 (Rev. A)
TPS543C20采用内部补偿的仿真峰值电流模式控制方式,具有适用于EMI敏感型POL的时钟同步固定频率调制器。内部积分器和直接放大式斜坡跟踪环路在较宽频率范围内消除了对外部补偿的需求,从而使用系统设计具有灵活,密集和简单的特点。可选的API和体制动功能有助于分别通过显着减少下冲和过冲来提高瞬态性能。具有低损耗开关特性的集成式NexFET™MOSFET有助于提高效率和提供高达40A的输出电流(采用5mm×7mm的PowerStack™封装,带有方便布局的散热垫) 。两个TPS543C20器件可以堆叠在一起,以便提供高达80A的负载点。
<小>所有商标是其相应所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS543C20 | TPS53353 | TPS53355 | TPS543B20 | TPS544C25 | TPS548B22 | TPS548D22 | TPS56221 |
| 4 | 1.5 | 1.5 | 4 | 4.5 | 1.5 | 1.5 | 4.5 |
| 16 | 15 | 15 | 19 | 18 | 18 | 16 | 14 |
| 0.6 | 0.6 | 0.6 | 0.6 | 0.5 | 0.6 | 0.6 | 0.6 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5 | 5.5 | 5.5 | 12 |
| 40 | 20 | 30 | 25 | 30 | 25 | 40 | 25 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 300 | 250 | 250 | 300 | 200 | 425 | 425 | 300 |
| 2000 | 1000 | 1000 | 2000 | 1000 | 1050 | 1050 | 1000 |
| 4.3 | 0.32 | 0.32 | 3 | 7.7 | 2 | 2 | 2.5 |
| Adjustable Current Limit Enable Frequency Synchronization N/A Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Frequency Synchronization Over Current Protection Phase Interleaving Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Dynamic Voltage Scaling Enable Frequency Synchronization PMBus Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification Tracking UVLO Adjustable Voltage Margining | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Remote Sense Synchronous Rectification UVLO Adjustable | Enable Light Load Efficiency Pre-Bias Start-Up Synchronous Rectification |
| Current Mode | D-CAP | D-CAP | Current Mode | Voltage Mode | D-CAP3 | D-CAP3 | Voltage Mode |
| 70 | 90 | 90 | 70 | 80 | 80 | 80 | 93 |
| -40 to 125 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| LQFN-CLIP | LSON-CLIP | LSON-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LQFN-CLIP | LSON-CLIP |
