数据: TPS6216x-Q1 3-V to 17-V 1-A Step-Down Converter with DCS-Control™ 数据表
TPS6216x-Q1是易于使用的同步降压DC-DC转换器,专为高功率密度应用而优化。高开关频率(典型值为2.25 MHz)允许使用小型电感器,并通过利用DCS-Control™拓扑结构提供快速瞬态响应和高输出电压精度。
具有宽工作输入电压范围该器件的电压为3 V至17 V,非常适合采用锂离子电池或其他电池以及12 V中间电源轨供电的系统。它在0.9 V和6 V输出电压(100%占空比模式)下支持高达1A的连续输出电流。
通过配置使能和漏极开路电源良好,也可以实现电源排序引脚。
在省电模式下,器件从VIN吸收约17μA的静态电流。省电模式,在负载较小时自动无缝输入,在整个负载范围内保持高效率。在关断模式下,器件关闭,关断电流消耗小于2μA。
器件提供可调和固定输出电压版本,采用8引脚WSON封装,尺寸为2× 2毫米(DSG)。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62162-Q1 | TPS62160-Q1 | TPS62170-Q1 | TPS62171-Q1 | TPS62172-Q1 |
| 3 | 3 | 3 | 3 | 3 |
| 17 | 17 | 17 | 17 | 17 |
| 3.3 | 0.9 | 0.9 | 1.8 | 3.3 |
| 3.3 | 6 | 6 | 1.8 | 3.3 |
| 1 | 1 | 0.5 | 0.5 | 0.5 |
| 1 | 1 | 1 | 1 | 1 |
| 2250 | 2250 | 2250 | 2250 | 2250 |
| 0.017 | 0.017 | 0.017 | 0.017 | 0.017 |
| Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification Tracking Voltage Margining | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Synchronous Rectification |
| Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control | Constant on-time (COT) DCS-Control |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive |
| WSON | WSON | WSON | WSON | WSON |
