数据: TPS6240x-Q1 2.25-MHz 400-mA and 600-mA Dual Step-Down Converter 数据表
TPS6240x-Q1系列器件是同步双路降压DC-DC转换器,针对电池供电的便携式应用和汽车系统进行了优化。它们提供两个独立的输出电压轨,由可充电电池或标准3.3V或5V电压轨供电。
EasyScale™串行接口允许在运行期间修改输出电压。固定输出电压版本TPS62402-Q1,TPS62404-Q1和TPS62405-Q1支持单引脚控制的简单动态电压调节,适用于低功耗处理器。
TPS6240x-Q1工作在2.25 -MHz固定开关频率,在轻负载电流下进入省电模式,在整个负载电流范围内保持高效率。对于低噪声应用,可以通过将MODE /DATA引脚拉高来强制器件进入固定频率PWM模式。关断模式可将电流消耗降至1.2μA(典型值)。这些器件允许使用小型电感器和电容器来实现小尺寸解决方案。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62400-Q1 | TPS62402-Q1 | TPS62404-Q1 | TPS62405-Q1 | TPS62406-Q1 | TPS62407-Q1 | TPS62410-Q1 | TPS62420-Q1 | TPS62422-Q1 | TPS62423-Q1 | TPS62424-Q1 |
| 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
| 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
| 0.6 | 1.2 | 1.575 | 1.575 | 1.125 | 1.225 | 0.6 | 0.6 | 1.15 | 1.2 | 1.1 |
| 6 | 1.8 | 1.9 | 1.925 | 1.125 | 1.225 | 6 | 6 | 1.8 | 1.5 | 1.3 |
| 0.4 | 0.4 | 0.4 | 0.4 | 1 | 0.4 | 0.8 | 0.6 | 0.6 | 0.8 | 0.8 |
| 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
| 2000 | 2000 | 2250 | 2250 | 2000 | 2000 | 2250 | 2250 | 2000 | 2000 | 2000 |
| 2500 | 2500 | 2250 | 2250 | 2500 | 2500 | 2250 | 2250 | 2500 | 2500 | 2500 |
| 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 |
| Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification UVLO Fixed | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification UVLO Fixed |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| VSON | VSON | VSON | VSON | VSON | VSON | VSON | VSON | VSON | VSON | VSON |
型号:TPS62400DRCR 封装:VSON10_3X3MM_EP
品牌:TI 描述:降压型 Vin=2.5V~6V Vout=600mV~6V VSON10_3X3MM_EP
金额:¥10.59999
去购买
