TPS54040A器件是一款42V,0.5A,降压稳压器,此稳压器具有一个集成的高侧MOSFET。电流模式控制提供了解单的低纹波脉冲跳跃模式将无负载,经调节的输入电源电流减少至116μA。通过使用使能引脚,当它为低电平时,关断电源电流降标称值为1.3μA。
欠压闭锁在内部设定为2.5V,但可采用使能引脚将之提高。输出电压启动斜坡受控于缓慢起动引脚,该引脚还可被配置用来控制电源排序或者跟踪。开漏电源状态良好信号表示输出处于其标称电压的94%至107%之内。
宽广的开关频率范围使得能够对效率及外部组件尺寸进行优化。频率折返和热关断功能在过载情况下对部件实施保护。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS54040A | TPS54140A | TPS54240 | TPS54340 | TPS54341 | TPS54540 | TPS54541 |
| 3.5 | 3.5 | 3.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 42 | 42 | 42 | 42 | 42 | 42 | 42 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 39 | 39 | 39 | 41 | 41 | 41.1 | 41 |
| 0.5 | 1.5 | 2.5 | 3.5 | 3.5 | 5 | 5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.116 | 0.116 | 0.138 | 0.146 | 0.152 | 0.146 | 0.152 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 98 | 98 | 98 | 98 | 98 | 98 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 | -40 to 125 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | SO PowerPAD | WSON | SO PowerPAD | WSON |
