数据: 具有 Eco-mode™ 的 TPS57060-Q1 0.5A 60V 降压直流/直流转换器 数据表 (Rev. C)
TPS57060-Q1器件是一款60V 0.5A降压型稳压器,集成了high-sideMOSFET。电流模式控制提供了简单的外部补偿和灵活的组件选择。低纹波脉冲跳跃模式将无负载稳压输出电源电流降至116μA。使能引脚处于低电平状态时,关断电流降至1.3μA。
其欠压锁定电压在内部设定为2.5V,但可用使能引脚将之提高。输出电压启动过程中的斜坡受控于缓启动引脚,该引脚还可用于配置时序和跟踪。开漏电源正常信号表示输出介于其标称电压的92%至109%范围之内。
宽开关频率范围允许对效率及外部组件尺寸进行优化。频率折返和热关断功能在过载情况下保护部件。
TPS57060-Q1器件采用10引脚耐热增强型MSOP-PowerPAD™封装(DGQ)和VSON(DRC)封装。
所有商标均为他们各自的所有者。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS57060-Q1 | TPS54240-Q1 | TPS54260-Q1 | TPS57040-Q1 | TPS57140-Q1 | TPS57160-Q1 |
| 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
| 60 | 42 | 60 | 42 | 42 | 60 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 58 | 39 | 58 | 39 | 39 | 58 |
| 0.5 | 2.5 | 2.5 | 0.5 | 1.5 | 1.5 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.116 | 0.138 | 0.138 | 0.116 | 0.116 | 0.116 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 98 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON |
