TPS4030x是成本优化的同步降压控制器系列产品,可在3V至20V输入电压下运行。此控制器实现了一种电压模式控制架构,具有输入电压前馈补偿功能,固定开关频率为300KHz,600KHz或1.2MHz。
在开关频率部分添加了扩频频谱(FSS) )特性,显着降低了峰值EMI噪声,使其更容易符合EMI标准。
TPS4030x具有多种用户可编程功能,包括软启动,过流保护(OCP)电平以及环路补偿。
OCP电平可以通过从LDRV引脚连接到电路接地的单个外部电阻器进行编程。在初始通电过程中,TPS4030x将进入校准环节,测量LDRV引脚电压,并设置内部OCP电压电平。在工作期间,器件可在通电时通过将已编程OCP电压电平与低侧FET上的压降进行比较来确定是否发生过流情况。之后,TPS4030x会进入关断和重启周期,直故障消除为止。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| TPS40304 | TPS40303 | TPS40304A | TPS40305 |
| 3 | 3 | 3 | 3 |
| 20 | 20 | 20 | 20 |
| 0.6 | 0.6 | 0.6 | 0.6 |
| 18 | 18 | 18 | 17 |
| 25 | 25 | 25 | 25 |
| 1 | 1 | 1 | 1 |
| 1 | 1 | 1 | 1 |
| 600 | 300 | 600 | 1200 |
| 2.5 | 2.5 | 2.5 | 2.5 |
| Enable Power Good Pre-Bias Start-Up Spread Spectrum Synchronous Rectification | Enable Power Good Pre-Bias Start-Up Spread Spectrum Synchronous Rectification | Enable Power Good Pre-Bias Start-Up Spread Spectrum Synchronous Rectification | Enable Power Good Pre-Bias Start-Up Spread Spectrum Synchronous Rectification |
| 90 | 90 | 90 | 85 |
| -40 to 125 | -40 to 125 | -40 to 145 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog |
| VSON | VSON | VSON | VSON |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
