TPS6200x器件是一系列低噪声同步降压DC-DC转换器,非常适合采用1节Li电源供电的系统离子电池或2至3节NiCd,NiMH或碱性电池。 TPS6200x的工作电压通常低至1.8 V,指定的最小输入电压为2 V.
TPS6200x是一款同步电流模式PWM转换器,集成了N和P通道功率MOSFET开关。同步整流用于提高效率和减少外部元件数量。为了在宽负载电流范围内实现最高效率,转换器在轻负载电流下进入节能脉冲频率调制(PFM)模式。工作频率通常为750 kHz,允许使用小电感和电容值。该器件可以与500 kHz至1 MHz范围内的外部时钟信号同步。对于低噪声操作,转换器可以在PWM模式下工作,内部反循环开关可降低噪声和EMI。在关断模式下,电流消耗降至1μA以下。 TPS6200x采用10引脚(DGS)微型外形封装(MSOP)。这些器件的工作温度范围为40°C至125°C。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62000-Q1 | TPS62004-Q1 | TPS62005-Q1 | TPS62007-Q1 |
| 2 | 2 | 2 | 2 |
| 5.5 | 5.5 | 5.5 | 5.5 |
| 0.9 | 1.5 | 1.8 | 3.3 |
| 5 | 1.5 | 1.8 | 3.3 |
| 0.6 | 0.6 | 0.6 | 0.6 |
| 1 | 1 | 1 | 1 |
| 500 | 500 | 500 | 500 |
| 1000 | 1000 | 1000 | 1000 |
| 0.05 | 0.05 | 0.05 | 0.05 |
| Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification |
| Current Mode | Current Mode | Current Mode | Current Mode |
| 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive |
| VSSOP | VSSOP | VSSOP | VSSOP |
