TPS6205x器件是一系列高效率同步降压DC-DC转换器,非常适合1-或2-供电的系统锂离子电池或3至5节NiCd,NiMH或碱性电池。
TPS6205x器件是具有集成的N和P通道功率的同步脉冲宽度调制(PWM)转换器MOSFET开关。同步整流可提高效率并减少外部元件数量。为了在宽负载电流范围内实现最高效率,转换器在轻负载电流下进入节能脉冲频率调制(PFM)模式。工作频率通常为850 kHz,允许使用小电感和电容值。该器件可以与600 kHz至1.2 MHz范围内的外部时钟信号同步。对于低噪声操作,可以在PWM模式下将转换器编程为强制固定频率。在关断模式下,电流消耗降至2μA以下。 TPS6205x器件采用10引脚(DGS)微型小外形封装(MSOP),工作温度范围为40°C至85°C。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62050 | TPS62051 | TPS62052 | TPS62054 | TPS62056 |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 10 | 10 | 10 | 10 | 10 |
| 0.7 | 0.7 | 1.5 | 1.8 | 3.3 |
| 6 | 6 | 1.5 | 1.8 | 3.3 |
| 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 1 | 1 | 1 | 1 | 1 |
| 600 | 600 | 600 | 600 | 600 |
| 1200 | 1000 | 1000 | 1000 | 1000 |
| 0.012 | 0.012 | 0.012 | 0.012 | 0.012 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| VSSOP | VSSOP | VSSOP | VSSOP | VSSOP |
