数据: 1.2A / 1.25 MHz. High-Efficiency Step-Down Converter 数据表
TPS6204x系列器件是针对电池供电的便携式应用而优化的高效同步降压DC-DC转换器。这些器件非常适合由单节锂离子电池或3节NiMH /NiCd电池供电的便携式应用。这些器件的输出电压范围为6.0 V至0.7 V,支持PDA,袖珍PC以及笔记本电脑和亚笔记本电脑中的低压DSP和处理器。 TPS6204x以1.25 MHz的固定开关频率工作,并在轻负载电流下进入省电模式工作,以在整个负载电流范围内保持高效率。对于低噪声应用,可以通过将MODE引脚拉高来强制器件进入固定频率PWM模式。 TPS6204x支持高达1.2A的负载电流。
PowerPAD是德州仪器公司的商标。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62044 | TPS62040 | TPS62042 | TPS62043 | TPS62046 |
| 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
| 6 | 6 | 6 | 6 | 6 |
| 1.8 | 0.7 | 1.5 | 1.6 | 3.3 |
| 1.8 | 6 | 1.5 | 1.6 | 3.3 |
| 1.2 | 1.2 | 1.2 | 1.2 | 1.2 |
| 1 | 1 | 1 | 1 | 1 |
| 1000 | 1000 | 1000 | 1000 | 1000 |
| 1500 | 1500 | 1500 | 1500 | 1500 |
| 0.018 | 0.018 | 0.018 | 0.018 | 0.018 |
| Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Power Good Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Power Good Synchronous Rectification |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON |
