TAS5704是一款20W,高效的数字音频功率放大器,用于驱动立体声桥接扬声器。两个串行数据输入允许处理多达四个离散音频通道,并与大多数数字音频处理器无缝集成,可接受各种输入数据和时钟速率。硬件可配置数据路径允许这些通道路由到内部扬声器驱动器或通过超低音扬声器PWM输出输出。
TAS5704是一个从器件设备,接收来自外部源的所有时钟。对于32,48,96和192 kHz数据,TAS5704的开关速率为384 kHz,对于44.1-,88.2-和176.4-kHz数据,开关速率为352.8 kHz。 8倍过采样与四阶噪声整形器相结合,可提供平坦的本底噪声和20 Hz至20 kHz的出色动态范围。
TAS5704的闭环架构具有多种优势。高功率电源抑制功能可通过嘈杂,低成本的电源实现卓越的音频性能。高阻尼系数允许更严格地控制扬声器移动,从而改善低音响应。最后,开关边沿速率控制可在不牺牲音频性能的情况下降低EMC辐射。
System Two,Audio Precision是商标Audio Precision,Inc。的作品
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| Power to Parallel Bridge Tied Load (Max) (W) |
| Sampling Rate (Max) (kHz) |
| PSRR (dB) |
| Operating Temperature Range (C) |
| Rating |
| TAS5704 | TAS5760L | TAS5760M |
| Digital Input | Digital Input | Digital Input |
| Class-D | Class-D | Class-D |
| 4 | Stereo | Stereo |
| 10 | 4.5 | 4.5 |
| 26 | 16.5 | 26.4 |
| 20 | 21 | 55 |
| 4 | 2 | 2 |
| 100 | 100 | 100 |
| 0.05 | 0.09 | 0.03 |
| 33 | ||
| Hardware | Hardware Software | Hardware Software |
| Closed | Closed | Closed |
| 3 | 4.5 | 4.5 |
| 3.6 | 16.5 | 26.4 |
| 60 | 43.2 | 43.2 |
| 192 | 192 | 96 |
| 60 | ||
| 0 to 85 | -25 to 85 | -25 to 85 |
| Catalog | Catalog | Catalog |
