数据: THS4561 Low-Power, High Supply Range, 70-MHz, Fully Differential Amplifier 数据表
THS4561全差动放大器(FDA)提供简单的接口,从单端源到高精度模数转换器(ADC)所需的差分输出)。该器件专为实现卓越的直流精度,低噪声和超低谐波失真而设计,非常适用于需要高精度且具有最佳信噪比(SNR)和无杂散动态范围(SFDR)的数据采集系统放大器和ADC组合。
当将直流耦合的,以地为中心的源信号连接到单电源差分输入ADC时,THS4561具有所需的负轨输入。极低的直流误差和漂移项支持新兴的16位至20位逐次逼近寄存器(SAR)输入要求。 2.85V至12.6V电源范围,灵活的输出共模设置,低电平余量,支持各种ADC输入和数模转换器(DAC)输出要求。
THS4561将作为VQFN-24封装中的THS4562提供双通道器件。
所有商标均为其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4561 | THS4531A | THS4541 | THS4551 | THS4552 |
| Fully Differential | Fully Differential Voltage FB | Fully Differential Voltage FB | Bipolar Fully Differential Voltage FB | Bipolar Fully Differential Voltage FB |
| 1 | 1 | 1 | 1 | 2 |
| 2.85 | 2.5 | 2.7 | 2.7 | 2.7 |
| 12.6 | 5.5 | 5.4 | 5.4 | 5.4 |
| 70 | 36 | 620 | 150 | 150 |
| 1 | 1 | 1 | 1 | 1 |
| 130 | 220 | 1500 | 220 | 220 |
| 5 | 10 | 2.2 | 3.3 | 3.3 |
| 5 | 10 | 33 | 3.3 | 3.3 |
| 0.82 | 0.25 | 10.1 | 1.35 | 1.37 |
| 0.2 | 0.4 | 0.45 | 0.175 | 0.265 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| Shutdown | Small Size Shutdown | Small Size Shutdown | Small Size Shutdown | Shutdown |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| VQFN VSSOP | QFN SOIC VSSOP | QFN VQFN | QFN VQFN VSSOP | TSSOP WQFN |
| 16VQFN: 9 mm2: 3 x 3(VQFN) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 16VQFN: 9 mm2: 3 x 3(VQFN) | 10QFN: 4 mm2: 2 x 2(QFN) 16VQFN: 9 mm2: 3 x 3(VQFN) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 24WQFN: 16 mm2: 4 x 4(WQFN) |
| 110 | 116 | 100 | 110 | 110 |
| 200000 | 250000 | 13000000 | 1500000 | 1500000 |
| 0.3 | 3 | 0.5 | 0.45 | 0.45 |
| 60 | 27 | 850 | 135 | 135 |
| 35 | 26 | 100 | 45 | 65 |
| 110 | 129 | 140 | 128 | 128 |
| 115 | 138 | 140 | 139 | 139 |
| 0.001 | 0.1 | 0.1 | 0.1 | |
