THS4531A是一款低功耗,完全差分运算放大器,此放大器具有低于负电源轨道和轨道输出的输入共模范围。此器件设计用于能耗和功率耗散都十分关键的低功率数据采集系统和高密度应用。
此器件特有精确输出共模控制,此控制可实现驱动模数转换器(ADC)时的dc耦合。与低于负电源轨和轨道轨道输出的输入共模范围相耦合,此控制可只使用2.5V至5V的单电源轻松实现单端接地基准信号源与逐次逼近(SAR)的连接和三角积分(ΔΣ)ADC的对接.THS4531A也是一款用于通用,低功率差分信号调节应用的实用工具。
THS4531A可在介于-40°C + 125°C的扩展工业温度范围内运行。可提供下列封装选项:
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4531A | THS4524 | THS4541 | THS4551 | THS4552 | THS4561 |
| Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Bipolar Fully Differential Voltage FB | Bipolar Fully Differential Voltage FB | Fully Differential |
| 1 | 4 | 1 | 1 | 2 | 1 |
| 2.5 | 2.5 | 2.7 | 2.7 | 2.7 | 2.85 |
| 5.5 | 5.5 | 5.4 | 5.4 | 5.4 | 12.6 |
| 36 | 145 | 620 | 150 | 150 | 70 |
| 1 | 1 | 1 | 1 | 1 | 1 |
| 220 | 490 | 1500 | 220 | 220 | 130 |
| 10 | 4.6 | 2.2 | 3.3 | 3.3 | 5 |
| 10 | 5.2 | 33 | 3.3 | 3.3 | 5 |
| 0.25 | 1.14 | 10.1 | 1.35 | 1.37 | 0.82 |
| 0.4 | 2 | 0.45 | 0.175 | 0.265 | 0.2 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| Small Size Shutdown | Shutdown | Small Size Shutdown | Small Size Shutdown | Shutdown | Shutdown |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| QFN SOIC VSSOP | TSSOP | QFN VQFN | QFN VQFN VSSOP | TSSOP WQFN | VQFN VSSOP |
| 10QFN: 4 mm2: 2 x 2(QFN) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 38TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 16VQFN: 9 mm2: 3 x 3(VQFN) | 10QFN: 4 mm2: 2 x 2(QFN) 16VQFN: 9 mm2: 3 x 3(VQFN) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 24WQFN: 16 mm2: 4 x 4(WQFN) | 16VQFN: 9 mm2: 3 x 3(VQFN) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
| 116 | 102 | 100 | 110 | 110 | 110 |
| 250000 | 900000 | 13000000 | 1500000 | 1500000 | 200000 |
| 3 | 2 | 0.5 | 0.45 | 0.45 | 0.3 |
| 27 | 95 | 850 | 135 | 135 | 60 |
| 26 | 55 | 100 | 45 | 65 | 35 |
| 129 | 133 | 140 | 128 | 128 | 110 |
| 138 | 141 | 140 | 139 | 139 | 115 |
| 0.001 | 0.001 | 0.1 | 0.1 | 0.1 | |
