OPA356-Q1是一款高速电压反馈CMOS运算放大器,专为视频应用和其他需要宽带宽的应用而设计.OPA356-Q1具有单位增益稳定性,可以驱动大输出电流。差分增益为0.02%,而差分相位为0.05°。静态电流只有8.3mA。
OPA356-Q1针对低至2.5V(±1.25V)和高达5.5V(±2.75V)的单电源或双电源供电运行进行了优化.OPA356-Q1的共模输入范围的下限可熔展至低于接地电压100mV,上限可以展开高于V + 1.5V。电源轨的输出摆幅在100mV以内,从而支持宽动态范围。
OPA356-Q1采用SOT23-5封装,额定温度范围为-40°C至125°C。
所有商标均为其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| OPA356-Q1 |
| CMOS Voltage FB |
| 1 |
| 2.5 |
| 5.5 |
| 450 |
| 1 |
| 300 |
| 5.8 |
| 5.8 |
| 8.3 |
| 9 |
| In to V- Out |
| Shutdown |
| Automotive |
| -40 to 125 |
| SOT-23 |
| 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 80 |
| 50000 |
| 7 |
| 450 |
| 100 |
| 81 |
| 93 |
| 1 |
