数据: 1.8V, 1μA max, Zerø-Crossover RAIL-TO-RAIL I/O OPERATIONAL AMPLIFIER 数据表
OPA369和OPA2369是TexasInstruments的超低功耗,低电压运算放大器,专为电池供电应用而设计。
OPAx369采用低至1.8V的电源供电,具有真正的轨到轨操作,适用于各种应用。 zerø-crossover 功能解决了输入交叉失真的问题,这种问题在低压(<3V),轨到轨输入应用中变得非常突出。
除了微型尺寸封装和极低的静态电流,OPAx369具有12kHz带宽,低失调漂移(1.75μV/°C,最大值)和低噪声3.6μV PP (0.1 Hz至10Hz)。
OPA369(单一版本)采用SC70-5封装。 OPA2369(双版本)采用MSOP-8和SOT23-8封装。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| Iq per channel (Max) (mA) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Features |
| Package Size: mm2:W x L (PKG) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Output Current (Typ) (mA) |
| Architecture |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| OPA2369 | LPV811 | LPV821 | OPA369 |
| 2 | 1 | 1 | 1 |
| 1.8 | 1.6 | 1.7 | 1.8 |
| 5.5 | 5.5 | 3.6 | 5.5 |
| 0.001 | 0.00054 | 0.00079 | 0.0012 |
| 0.0007 | 0.00045 | 0.00065 | 0.0008 |
| 0.75 | 0.37 | 0.01 | 0.75 |
| 0.4 | 1 | 0.02 | 0.4 |
| 0.012 | 0.008 | 0.008 | 0.012 |
| 0.005 | 0.0017 | 0.0033 | 0.005 |
| In Out | In to V- Out | In Out | In Out |
| Catalog | Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 125 | -40 to 125 | -40 to 85 |
| SOT-23 VSSOP | SOT-23 | SOT-23 | SC70 |
| EMI Hardened Zero Crossover | EMI Hardened | Zero Drift EMI Hardened | EMI Hardened Zero Crossover |
| 8SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) |
| 290 | 420 | 215 | 290 |
| 10 | 4.7 | 21 | 10 |
| CMOS | CMOS | CMOS | |
| 50 | 50 | ||
| 114 | 95 | 125 | 114 |
