THS4513是一款宽带全差分运算放大器,专为3.3 V至5 V数据采集系统而设计。它的噪声非常低,为2.2 nV /√ Hz ,极低的谐波失真为-75 dBc HD 2 和-86 dBc HD 3 ,70 MHz,2-V PP 输出,G = 0 dB,200- 加载。压摆率非常高,为5100 V /μs,建立时间为2.9 ns至1%(2 V步进),是脉冲应用的理想选择。它的最小增益为0 dB。
为了实现与模数转换器(ADC)的直流耦合,其独特的输出共模控制电路可保持输出共模电压当设定电压在0.5 V以内时,设定电压的偏移(典型值)为5 mV,差分偏移电压小于4 mV。共模设定点由内部电路设置为中间电源,内部电路可能从外部源过驱动。
输入和输出经过优化,可以将共模电压设置为中间电源,从而获得最佳性能。除了在低电源电压下的高性能外,该设计还使其成为极高性能,单电源5 V数据采集系统的理想选择。
THS4513采用四通道无引脚QFN-16封装(RGT),工作温度范围为-40°C至+ 85°C。
所有商标均为其所属商标拥有者。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4513 | THS4508 | THS4509 | THS4511 |
| Voltage FB | Fully Differential | Fully Differential | Fully Differential Voltage FB |
| 1 | 1 | 1 | 1 |
| 3 | 3.75 | 3 | 3.75 |
| 5.5 | 5.25 | 5.25 | 5.25 |
| 1600 | 2000 | 2000 | 1600 |
| 1 | 2 | 2 | 1 |
| 5100 | 6400 | 6600 | 4900 |
| 2.2 | 2.3 | 1.9 | 2 |
| 27 | 2.3 | 10 | 20 |
| 37.7 | 39.2 | 37.7 | 39.2 |
| 4 | 4 | 4 | 4 |
| No | In to V- | No | In to V- |
| Shutdown | Shutdown | Shutdown | Shutdown |
| Catalog | Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| VQFN | VQFN | VQFN | VQFN |
| 16VQFN: 9 mm2: 3 x 3(VQFN) | 16VQFN: 9 mm2: 3 x 3(VQFN) | 16VQFN: 9 mm2: 3 x 3(VQFN) | 16VQFN: 9 mm2: 3 x 3(VQFN) |
| 90 | 90 | 90 | 90 |
| 15500000 | 15500000 | 15500000 | 15500000 |
| 2.6 | 2.3 | 2.6 | 2.3 |
| 2800 | 3000 | 3000 | 2000 |
| 96 | 96 | 96 | 96 |
| 110 | 104 | 104 | 117 |
| 108 | 105 | 108 | 106 |
| 10 | 10 | 10 | 10 |
